Old 05-18-2015, 06:22 AM   #1
FrankWest
FrankWest's Avatar
Default Non-Detergent Motor Oil
Looking for quality Non detergent Motor oil in grades sae 30 and 40
I am using Valvoline sae 30 but think I should be using sae 40?
It seems that Non-detergent oil is sold by unusually producers.
Anyone ever use Amalie Oil??
Any suggestions.
FrankWest is offline   Reply With Quote
Old 05-18-2015, 06:30 AM   #2
48 coupe
48 coupe's Avatar
Default Re: Non-Detergent Motor Oil
Non det. hard to find in my area. Just go to a 90 wt. gear oil. I think that is about 50 wt. oil.
48 coupe is offline   Reply With Quote
Old 05-18-2015, 08:06 AM   #3
Jeff/Illinois
Jeff/Illinois's Avatar
That being said 'tongue in cheek' right?? I sure hope so
Old 05-18-2015, 08:17 AM   #4
TJ
TJ's Avatar
Why do you think that you need to use non-detergent oil?
Old 05-18-2015, 08:19 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
I wouldn't use AMALIE on a squeaky door hinge. First-hand experience many years ago..........baaaaaaaaaaad! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-18-2015, 08:38 AM   #6
GB SISSON
GB SISSON's Avatar
If you insist on non detergent oil, it's commonly used in air compressors. Not the tool oil, but for the crank case of the compressor itself. Most people under age 90 run conventional oil in these engines today. Some say if it's an old unopened engine that detergent oil can break loose sludge free which then clogs the screen or that the sludge was holding things together in there. The first part of that statement could be true.....
GB SISSON is online now   Reply With Quote
Old 05-18-2015, 08:55 AM   #7
1938 Woody Cape Cod
1938 Woody Cape Cod's Avatar
Tractor Supply has it
1938 Woody Cape Cod is offline   Reply With Quote
Old 05-18-2015, 08:57 AM   #8
FrankWest
FrankWest's Avatar
I have an original engine car. The car was stored for 20 years without running.
When I purchased the car, I dropped the oil pan and it was not bad.. about and inch of sediment..that was like sand..not greasy sludge. I was told that that type of pan deposit is a result of running non-detergent oil. I got the car running and added a quart of MMO. Now I want to begin frequent oil changes to clean the engine.
Are you telling me that most of you guys running 80 year old engines use regular
bargan basement motor oil? I'm so confused.
Old 05-18-2015, 09:04 AM   #9
deuce_roadster
deuce_roadster's Avatar
The "detergent" in the oil is actually additives to combat the contaminants from the combustion chamber that leak past the rings and moisture. If you have already cleaned the pan, use any modern oil that you would consider a "detergent" oil. I wouldn't use "non detergent" in a lawn mower.
Old 05-18-2015, 09:12 AM   #10
FrankWest
FrankWest's Avatar
Do you run regular detergent oil in your 80 year old UN-rebuilt engine?
Old 05-18-2015, 09:20 AM   #11
Mart
Mart's Avatar
As long as you have de-sludged it, any reasonably good modern oil will be ok.
Anything from the supermarket cheapie to the most expensive one you can find will all work ok. Old engines tend to leak more than modern engines, I use that to support my likeness for oil from the cheaper end of the price scale.
Plus I'm tight.
Mart.
Old 05-18-2015, 09:30 AM   #12
51 MERC-CT
51 MERC-CT's Avatar
Yes, I am running detergent oil in my never rebuilt 63 year old Merc. with 110K on the odometer.
Don't know what "bargain basement oil" is?
Old 05-18-2015, 09:55 AM   #13
JSeery
JSeery's Avatar
In the olden days it was fairly common to clean out an engine by running it on a kerosene and light weight oil mixture for a short time. Then drain it out and use regular oil.
Old 05-18-2015, 09:56 AM   #14
B-O-B
B-O-B's Avatar
Not a 4 banger but I do run 10/40 detergent oil in it. Most times I get my oil from wal-mart. They seem to have the most reasonable prices. On occasion the parts stores will run a promotion ad & I will stock up then.
B-O-B is offline   Reply With Quote
Old 05-18-2015, 10:01 AM   #15
Uncle Bob
Uncle Bob's Avatar
Here we go again.
DO NOT use hypoid gear lube in a crankcase just because the viscosity may be of a similar grade to what you want to use. The extreme pressure additive contains sulfur/phosphorus which will dine on your main and rod bearings.
It is true that piston type compressor oils typically don't contain detergents, and can be had in correct viscosity grades for a motor vehicle, however they are often made from naphthenic base stocks that are less thermally stable than the parafinic base stocks that every non-synthetic crankcase oil is made from.
Crankcase oil detergent/dispersants don't act like an often advertised bathroom cleaner.......they are not "scrubbing bubbles". Their primary action is to suspend contaminants (mostly by-products of combustion as correctly noted by deuce roadster). Most dislodging of built up deposits comes from fluid movement.
Putting a "quart" of MMO in an engine would probably cause much more "detergent" like action than regular motor oil since it contains a solvent.
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 05-18-2015, 10:03 AM   #16
Scott H in Wheaton
Scott H in Wheaton's Avatar
Old Ford flathead oil is a lot like Chicago politics.
"Vote early and vote often"
"doesn't matter who you pick, its always the same old BS"
so change your oil often, and because these old engines have fairly loose tolerences and run kind of dirty they will work fine on just about any type of clean oil...detergent/non-detergent. single viscosity vs multi-viscosity, 30w vs 50w
Scott H in Wheaton is offline   Reply With Quote
Old 05-18-2015, 10:19 AM   #17
zzlegend
zzlegend's Avatar
Yes. In all three of mine. Walmart, shell rotella 15-40. You cleaned the pan, now run detergent oil. Your sedan will thank you.
zzlegend is offline   Reply With Quote
Old 05-18-2015, 10:24 AM   #18
FrankWest
FrankWest's Avatar
Sorry for bringing it up.
Now I remember the big argument about oils.
I was not asking, if I should use non-detergent. I was asking where to get it.
I know there are many positions on what to use.
One guy even recommended to use synthetics in his model A.
I just do not want to KILL my engine by using the wrong stuff. That's all.
One guy said something last time that really scarred me.
He use a special detergent oil to clean his engine and it clogged the engine up.
When he removed the pan..he found something that looked like black corn flakes and the oil pump screen was also clogged.
Old 05-18-2015, 10:48 AM   #19
trainguy
trainguy's Avatar
Even modern "bargin basement oil" is better than the best oil available back in the 30s and 40s.
trainguy is offline   Reply With Quote
Old 05-18-2015, 10:56 AM   #20
Ronnie
Ronnie's Avatar
This is 2015 not 1915 Things change in the oil world.
Ronnie is offline   Reply With Quote
