Old 08-09-2012, 12:40 PM   #1
Cape Codder
Cape Codder's Avatar
Default Battery Requirements
I was wondering if a battery with 730 Cranking Amps and 590 CCA is sufficient or should the cranking amps be more to supply power to the Model A starter.
Thanks for your time.
Joe Grobleski
Cape Codder is offline   Reply With Quote
Old 08-09-2012, 02:04 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Battery Requirements
6 volt or 12 volt?
Stock or modified (high compression head, for example)?
If anywhere near stock, this is more than enough battery.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 08-09-2012, 03:38 PM   #3
Cape Codder
Sorry, its a 6 volt system although it will have a touring cam and high compression head.
Thanks,
Joe Grobleski
Old 08-09-2012, 03:45 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I bought an Optima battery, 1,000 cranking amps & 850 cold cranking amps!!
If I run out of gas,+&$*%@%, I can probably "CRANK"myself down to Bad Bud's for gas! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-09-2012, 06:21 PM   #5
Bruce Adams
Bruce Adams's Avatar
I have an Optima 6 volt battery with a high compression head, and cranking is not a challenge.
My Optima would race Bill's to Bad Buds for a Bud.
Bruce Adams is offline   Reply With Quote
