I'm replacing the subframe rails (door to rear) on both sides along with the rear cross member on my 31 coupe. Is it better to assembly them and them mount them or replace on rail at a time?
Depends.... How do you have the body braced? What are you using for a fixture?? You really cannot do a correct job of riveting doing it piece by piece but if you don't have a way of holding the subrails square with the rest of the body, that may be the best way for you.
I'm not planing on using rivets. I don't have a way of working with them. I was planning on using bolts.
