3x plugs with high compression head
What about it???
Bob from Northport Northport, Michigan |
Should work fine, no problem.
Best gap for 3x plugs in model a with high compression head
That would be good info for me to have too. I'm about to install a set of 3X plugs in my fresh rebuild with Brumfield 5.9 head.
#6 | |
www.whidbeymodelaclub.com |
0.035 inch gap. With higher compression it will take more voltage to jump the gap, but an ignition system in good condition should have no problem with this gap even with the normal high compression head. An engine with a plugs with smaller gaps will not idle as well.
Run the plugs at your normal cruising speed and operating temperature for half an hour. Park without running the engine too much at a slower speed. Then take the plugs out to read them. The electrodes should be tan with no carbon or signs of burning. If the plugs show any sign of burning, try a plug with a slightly colder heat range. Read the plugs again after several hundred miles. If you are getting carbon on the electrodes then your engine could be burning oil. If this is a real problem for you then try a plug with a slightly higher heat range.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-30-2024 at 08:13 PM. |
