12-16-2023, 12:06 PM | #1 |
52-53 Merc Fog Lights
After a lengthy serch I've found all the parts neccessary to install fog lights on my 52 merc. I'm cheap so I bought parts individually to avoid paying inflated e-pay prices. Can anyone help with where the switch mounts and harness routing? It's not going to be 100% as stock but I'd like to install everything close to as it was originally.
Thanks, Rob |
12-16-2023, 12:28 PM | #2 |
Re: 52-53 Merc Fog Lights
Ok, mine are on my 53' Merc (a bit different housing, but really the same). The switch mounts below the dash. While you are there, you might consider going LED. I did and they are actually better.
As to the wiring, you will need a hot source (Neg lead if you car is still Pos ground.). I would follow the wiring path for the head lights, then wrap the wires accordingly. |
12-16-2023, 12:30 PM | #3 | |
12-16-2023, 05:00 PM | #4 |
Oh it makes sense now. I couldn't figure out where the switch went. Thanks Roy! Always love seeing pictures of your 53!
Rob |
12-17-2023, 12:11 AM | #5 |
1940 Mercury Looking for DENVER heads - 81AS - 99AS - 19AS |
