09-26-2023, 04:20 PM | #1 |
Loose door handle 41 Super Deluxe Coupe
I recently purchased a very nice 41 Super Deluxe long door coupe. Th PO stuck a king's ransom having this car professionally restored. My wife went to enter the passenger side, only to have the door handle come out of the door in her hand. Upon inspection, I found a threaded well for what I took to be meant for a set screw. After acquiring and installing an appropriate 12/24 set screw, I found that the handle would not turn. What am I missing here ?
09-26-2023, 05:38 PM | #2 |
Re: Loose door handle 41 Super Deluxe Coupe
You probably will have to remove the door panel and see what's wrong with either the door locking mechanism or the handle mechanism.
09-26-2023, 09:59 PM | #3 | |
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
09-27-2023, 05:29 AM | #4 |
could it of been that the door was in the locked position ?
09-27-2023, 09:17 AM | #5 |
John, just a thought. The door handle came out when your wife pulled on it. You replaced the set screw used to anchor the assembly and the lock does not turn now. Perhaps the old owner left out the setscrew intentionally in order to access the car. Remove the set screw and see if the entire handle turns allowing the lock mechanism to turn. If it works the problem is in the handle assembly.
09-27-2023, 10:17 AM | #6 |
