06-19-2019, 10:35 AM | #1 |
Wheel Alignment
Need to get my front end aligned on my 55 Victoria. Don't know what the Caster, Camber, And Toe-in is. If someone has these I would appreciate them. Thank you so much.
06-19-2019, 11:53 AM | #2 |
Re: Wheel Alignment
from shop manual:
Caster; 1/2 degree to 1 1/2 degree The max diff between wheels should be 1/2 degree Camber; 1/4 degree to 1 1/4 degree The max diff between wheels should be 1/4 degree toe; 1/16" to 1/8" |
06-19-2019, 12:09 PM | #3 |
Re: Wheel Alignment
IF the car has radial tires the caster can be slightly increased from stock.
06-19-2019, 02:53 PM | #4 |
Re: Wheel Alignment
Thankyou guys I appreciate the information.
06-19-2019, 03:05 PM | #5 |
Re: Wheel Alignment
Thank you guys I appreciate the information.
02-27-2023, 09:39 AM | #6 |
Re: Wheel Alignment
02-28-2023, 08:08 PM | #7 |
Re: Wheel Alignment
Sorry about that ...
CASTER and CAMBER will be positive.
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
03-01-2023, 08:44 AM | #8 |
Re: Wheel Alignment
Thanks for the reply Kultulz but where I'm confused is most everything I read calls for negative camber and positive caster
03-01-2023, 08:53 AM | #9 |
Re: Wheel Alignment
No problem.
Read This - https://www.motortrend.com/how-to/cc...ignment-guide/ Any questions, get back.
03-02-2023, 07:31 AM | #10 |
Re: Wheel Alignment
That article is contradicting stating negative camber. Still confused
03-02-2023, 08:43 AM | #11 | ||
Re: Wheel Alignment
03-02-2023, 09:42 AM | #12 | |
Re: Wheel Alignment
Caster is the tilting of the wheel front to back. Camber is the tilting of the wheel side to side. If you have negative caster your car will drive skittish and tend to wander with positive caster your car tend to steer straight ahead. Camber is to keep the tire flat on the the thread. Negative camber is used to aid in keep the thread flat to pavement in turns. Too much and the tire will wear on the inside |
03-02-2023, 12:59 PM | #13 |
Re: Wheel Alignment
03-03-2023, 07:36 AM | #14 |
Re: Wheel Alignment
Now I'm even more confused from your last article. I totally understand caster and camber. My concern was about the shop manual not stating + or - specs. This last article states - caster and + camber on older vehicles. I'm assuming my 56 Fairlane is considered to be older
03-03-2023, 09:18 AM | #15 | ||
Re: Wheel Alignment
03-03-2023, 09:27 AM | #16 | |
Re: Wheel Alignment
Now this is WORD OF MOUTH but is correct (IMO)-
Next step will be me low crawling down my basement stairs to find my WSM.
03-03-2023, 05:26 PM | #17 |
Re: Wheel Alignment
Appreciate all of your help and yes I have the 1956 shop manual for my car and it does not specify + or - on the specs. That's where I am confused. Again thank you for your help
03-05-2023, 08:47 AM | #18 |
Re: Wheel Alignment
Follow up on my alignment. I did find the info needed in the Motor Parts Manual. All readings are positive which surprises me. I'm now attempting to do some adjusting. Thanks all
03-05-2023, 09:30 AM | #19 | |
Re: Wheel Alignment
Why surprised with all the TECH INFO I gave? Not b!tching but wondering.
03-06-2023, 07:36 AM | #20 |
Re: Wheel Alignment
surprised because most all articles insist on negative camber
