04-23-2021, 06:42 PM | #1 |
49 ford clutch chatter
i put in new clutch , pressure plate , throw out bearing , pilot bearing. and had the flywheel surfaced . when you let out the clutch it shakes the whole car terrible... no funny noises and the pedal feel good it has new motor and trans mount and everything is tight and its not lowered ... can anyone tell me what could be wrong before i take out the trans. and if i take out the trans what would i look for? i did a search and found the chutch could be in backwards is this poss? it feel like the clutch is working right. its a 49 ford car 239 ci. 3 speed no overdrive. thanks for any help . thanks, tony
04-23-2021, 07:35 PM | #2 |
Re: 49 ford clutch chatter
If the clutch was in backwards, it wouldn't work at all.
Is this clutch setup an offshore cheapie, brand X, or is it a well known brand ? .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. |
04-23-2021, 08:45 PM | #3 |
thats what i thought too, the pedal feels good... i dont remember the brand but it came from shoebox central
04-23-2021, 09:04 PM | #4 |
Bad motor mounts can cause this problem, Have you checked them out?
04-23-2021, 09:20 PM | #5 |
motor and trans mounts are new
04-23-2021, 10:11 PM | #6 |
I think that before I tore it apart, I'd try one more thing. I believe I would put the front bumper against a big ol' tree and try aggressively slipping that clutch and burning it in for a few seconds. DD |
04-24-2021, 06:53 AM | #7 |
The emergency and chock blocks on all4 wheels will not damage the bumper or any other part.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-24-2021, 07:09 AM | #8 |
Tony, check your PM's
04-24-2021, 07:29 AM | #9 |
sounds like the fingers on the PP are out of adjustment,you have to remove trans,i would get a clutch from fort wayne clutch and be done with it
04-24-2021, 07:50 AM | #10 |
i seen the new pressure plate had bolts that adjust where the throw out bearings ride i dont think my old one had these . my old parts were still good but thought i would put in new parts while it was apart. mistake... i havent tried burning it in . it shook so bat i didnt want to run it
04-24-2021, 07:55 AM | #11 | |
I bought a Centerforce "package" (duel friction/PP and flywheel) for less than a 100 dollar$ difference drop shipped from JEGS. Much easier on the leg than the 68 Mustang 10" I was using and good to 500hp |
04-24-2021, 07:59 AM | #12 |
burning it in
an old wives tale because someone did an install with dirty/greasy hands or components. Yes I did it once until I was taught better (cleanliness next to Godliness) |
04-24-2021, 08:04 AM | #13 |
The theory of chatter: the enemy grease oil which being all new parts I say thats out.
Clutch chatter is much like a warped brake rotor like a clutch disk - it grabs runs free grabs over and over, that's chatter. resurfaced fly wheel, that's good. My bet is the disk has face run out. If the disk was chucked up in a mandrel in a lathe the dial indicator may go crazy with face run out -its just not flat on both sides- we knew this back then and used the tree to burnish it in using 2nd or 3rd speed. Myself new everything and it chattered so I take off in 2nd just slipping the clutch now its fine try that seemed to ware off the high spots. bottom line think of this new or rebuilt on the disk, its linings removed, bead blasted new linings riveted on, in the box and out the door-quality control No. and the same goes for the pressure plate too ! |
04-24-2021, 08:18 AM | #14 |
im gonna try and get it apart today but i dont really know what im looking for. i guess if everything look ok i will order another a new clutch kit from ft wayne
04-24-2021, 08:51 AM | #15 |
I agree that "burnin' it in" probably won't work. Has anyone ever done it successfully?
You may also want to check this thread out where I was able to deal with uneven fingers on a pressure plate : https://www.fordbarn.com/forum/showt...pressure+plate. |
04-24-2021, 01:15 PM | #16 |
The old 9 1/2-inch Long type clutch in it's original form is a pretty good clutch. I don't trust the modern reproductions. I send all my OEM clutches to Ft Wayne Clutch for rebuild and haven't had a problem yet. I send all my Mercury 10-inch Borg & Beck clutches too and they have never had a problem with a properly resurfaced flywheel.
The late type diaphragm clutches are good but they are generally on a Borg & Beck type bolt pattern and they require special fingers to work with the OEM throw out bearing. |
04-24-2021, 05:50 PM | #17 |
I spoke to Fort Wayne clutch about this. There is no diaphragm pressure plate to fit the 9.5” pattern of the 49-51 cars. I ended up buying a 10” diaphragm pressure plate with the long 10” pattern from FW clutch, and will have the flywheel redrilled for 10” long. I also got an early T-bird clutch disc 10” with the correct 1”, 10 spline center for the original 49-51 transmission. I haven’t tried any of this out yet! Ken
04-24-2021, 07:40 PM | #18 |
i took the clutch out today and it looks good and everything was tight i looked at fort waynes kit and it looks the same as what i have im not really sure what to do . i dont think you could put the clutch in backwards, it wont fit into the flywheel. any sugestions ? thanks tony
04-24-2021, 08:24 PM | #19 |
Make sure your clutch release bearing is a good fit on the release hub and is not cocked hitting the fingers unevenly.
04-24-2021, 08:45 PM | #20 |
I would at least check the "fingers" and make sure they are close to even.
