10-19-2023, 02:38 PM | #1 |
Kwik-way line boring
Was looking at purchasing a kwik-way line boring set up. Can we still get the tool bits that are 5/16th inches to make face off cutters?
10-19-2023, 03:18 PM | #2 |
Re: Kwik-way line boring
If you talk to your local insert tooling supplier ,he will have something.
I got all insert tools for my old boring bar. Lawrie |
10-19-2023, 03:24 PM | #3 |
I tried Goodson and Regis and McMaster Carr. No luck. If you have a name of a supplier, I would appreciate it.
10-19-2023, 06:43 PM | #4 | |
If you are going to use it to face a thrust surface, you will probably have to grind it yourself and dial it in on the bar you will use. |
10-19-2023, 08:05 PM | #5 |
Try Lacy Williams Equipment—- 908-387-0087
Don’t know about now, they used to have insert cutters for LBM, perhaps they have thrust cutter too |
10-19-2023, 08:46 PM | #6 |
As Carroll Smith wrote; All Failures are Human in Origin. |
10-20-2023, 12:46 AM | #7 |
Not sure that Coder has line boring tools, but worth a call. If not, any tool and cutter grinding shop can grind round high speed steel cutter blanks into facing tools.
10-20-2023, 08:34 AM | #8 |
Thanks to all. I’ll continue my search with this info.
10-20-2023, 02:58 PM | #9 |
let me know if you want some pics of the tooling I made using the inserts tools.
Lawrie |
10-20-2023, 04:40 PM | #10 |
MSC Industrial Supply. Part #72678121. It will say TRC5 C2 on it.
They just need a little massaging to work. The back round side should be sanded down a little until they just slide thru the hole in the bar. Try it like it is, but I massaged the tip with a touch more radius to get it to cut like I like. They also have one that will work for the facing cutter I don't remember the part number. |
10-20-2023, 05:01 PM | #11 | |
Hey Mr. 'R'., ...that was always the issue I had when I had the K-W style cutters made was that the boring bar hole seemed like it was about 0.001-0.002 undersized from what they started as blanks. I haven't used my LBM in awhile but I also recall that the OE set screws had an imbedded ball to align the cutter to be parallel with the length of the bar. The original K-W cutters had a groove in them, didn't they? What do you do when you are using those MSC cutters with K-W set screws? Do you grind a groove in those or change out the set screw? |
10-20-2023, 05:36 PM | #12 |
A simple flat on the tool bit seems to work just as well as the OE groove.
10-21-2023, 12:53 AM | #13 |
Yes as Dan says the flat works just fine. and the fact that you have to take a little off
the MSC cutters to get them to fit the hole you can get a good fit and the cutters don't move. |
