01-14-2019, 12:08 AM | #1 |
Turn signals: ground or isolate terminal block
I am installing a turn signal in my 31 TS. Can I mount the terminal block that all the wires will feed in to and out of on an inside panel (metal) or does it have to be insulated from grounding? Thank you in advance.
01-14-2019, 12:14 AM | #2 |
Re: Turn signals: ground or isolate terminal block
It would have to be insulated.
01-14-2019, 04:28 AM | #3 |
