07-16-2019, 05:19 AM | #1 |
Ashtray Radio Installation.
Can anyone help me with location of holes in the firewall for mounting the radio box for ashtray radio in my 34.
The Ford Service Bulletins for May-June 1934 show a template in fig 269 but no dimensions. Thanks Graham |
07-16-2019, 07:07 AM | #2 |
Re: Ashtray Radio Installation.
My 34 had dimples in the firewall where the holes are to be drilled.
07-16-2019, 08:29 AM | #3 |
Graham, Is your car left or right hand drive. ? Regardless of that the center control radio box must be mounted on the left side of the dash/firewall. ie, passenger side on a right hand drive car or drivers side on a left hand drive car. Its the only place it can be fitted to enable the control head cables to reach the side of the radio box. There was a cardboard template for the holes position which came with the original instruction book. You can buy a reproduction copy of original instructions but I am not sure if it has the template in that book. My copy did not have it inside. Threë 7/16 holes are required to be drilled in the horizontal firewall panel at the provided dimples. Do you have a mounting kit which consists of three T head bolts, nuts and large flat washers ? If your car is RHD then the radio box should still fit under the glove box. Regards, Kevin.
07-16-2019, 10:12 AM | #4 |
Here is a photo of the location of the dimples on an original 34 cowl that JimTN is referring to.
07-16-2019, 10:59 AM | #5 |
Hopefully I can clarify the radio receiver box location in the '33-34 & '35-37 cars.
The Ford Philco receiver box has to be mounted on the left side of the car and that is where the location dimples in the cowl are usually located. The control cables are located on the right side of the receiver box for attachment of the center mounted control head. I would surmise that the glove box would require a modification, making it shorter to clear the receiver box. I would make a guess that Ford-Philco most likely never made a receiver box for a right hand drive vehicle.
Bill.... 36 5 win cpe |
07-16-2019, 02:30 PM | #6 |
Assumption is the mother of all foul-ups. |
07-16-2019, 04:21 PM | #7 |
It is LHD (ex USA) it appears to have had holes but they have been filled at some stage where the dimples would have been.
I presume there were only 2 holes that supported the the box itself? The 3rd hole that shows in Fig 269 is for the speedo cable support only? this has also been filled. Some accurate dimensions from someone for the 3 holes from the bend in the firewall and in from the cowl side would be greatly appreciated. Thanks Graham |
07-16-2019, 08:41 PM | #8 | |
Kevin feels that the radio will clear the glovebox on my RHD drive car . I think there are two T bolts rather than 3 but these are freely available or fabricated . I have no dimples on my firewall either - and would appreciate some X Y measurements to locate where to drill on mine as well - Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
07-16-2019, 09:43 PM | #9 |
On my LHD '34, the T-Bolts are exactly 11 inches apart center to center. They are exactly 2 inches (center of bolt) from the top vertical of the firewall. As seen in the attached picture, the T-Bolt on the right is 1-5/8 inches (center of bolt) from the right edge of the firewall. The hole for the speedo cable looks to be 3/4 inch in diameter and is located right above the lower lip of the firewall and 1-1/2 inches (center of hole) from the right edge of the firewall. I'm not sure but the hole for the speedo cable on my car may have been enlarged, or maybe not....
BTW - My car did have the dimples on the firewall for the correct bolt locations....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 07-17-2019 at 01:45 AM. |
07-17-2019, 02:21 AM | #10 |
Thanks Pete,
Exactly what I was after, will drill holes tomorrow. Many thanks, Graham |
07-17-2019, 05:59 PM | #11 |
Ditto exactly what I need as well -Karl
