01-01-2018, 05:27 PM | #1 |
Clutch Shaft Removal
Hey all,
Quick question from the frozen north: Can the clutch pedal shaft be removed and changed with the tranny still in the car? I'm planning on doing it in my 30 Tudor. Thanks, Jon |
01-01-2018, 05:55 PM | #2 |
Re: Clutch Shaft Removal
If your referring to the shaft the clutch and brake pedal are attached to i’ve Done it twice ..and if you search under my name and pedal shaft removal you should see my write up on the process
01-01-2018, 05:58 PM | #3 |
