Old 10-31-2017, 09:22 AM   #1
firerod
Default Painted valve springs?
I had my engine rebuilt approx. 500 miles ago. I pulled the intake off to change it and noticed the guy that rebuilt my engine used yellow painted valve springs. Some of the paint is flaking off, should I be worried? I would call the re-builder but he has since passed away.
firerod is offline   Reply With Quote
Old 10-31-2017, 09:37 AM   #2
RalphM
RalphM's Avatar
Default Re: Painted valve springs?
No worries, a lot of them are done that way.
RalphM is offline   Reply With Quote
Old 10-31-2017, 10:11 AM   #3
DavidG
DavidG's Avatar
Most NOS valve springs came painted brown, so as RalphM indicated, worry about something else.
Old 10-31-2017, 10:24 AM   #4
Jack E/NJ
Jack E/NJ's Avatar
Google "valve spring" "color codes" with the quotes. Jack E/NJ
Old 10-31-2017, 01:59 PM   #5
firerod
Thanks for the ease of mind. All I could think about was tearing it down and cleaning.
Old 10-31-2017, 03:00 PM   #6
Joe Immler
Is there any particular reason that they were painted? Painted by size, strength etc? Seems a waste of time and paint for something that will be immersed in oil its whole career.
Joe Immler is offline   Reply With Quote
Old 10-31-2017, 03:44 PM   #7
firerod
Just to be clear, the flaking paint won’t hurt anything?
Old 11-01-2017, 11:01 AM   #8
RalphM
RalphM's Avatar
I believe the Isky valves springs I last used were painted grey. I have seen entire engine blocks painted inside, why, no one will ever see them. I do not believe there is enough paint on a set of valve springs to do any engine damage. If your worried, change your oil, thats where it ends up.
Old 11-01-2017, 12:52 PM   #9
hardtimes
hardtimes's Avatar
The last set of Isky springs that I used were not painted.
As to 'why'...blocks painted inside; glyptol the reddish special paint that is used for that purpose is for 'sealing' porous castings; for shedding sludge and for allowing engine lube to return more quickly to sump. Maybe other reasons that I'm not aware of.
If the paint that you see therein, is other than glyptol , I'd be shaking my head at that...my opinion, your choice !
Old 11-01-2017, 01:29 PM   #10
itslow
itslow's Avatar
The paint is to aid identification during assembly.
Assume you have a number of bins full of valve springs that are visually identical, but with differing mechanical or material properties. What's the easiest and quickest way for an assembler to know which spring is which?
Keep in mind that this method of identification is not standardized. One manufacturer may use green paint on its valve spring while another manufacturer uses yellow for their identical equivalent.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 11-01-2017, 03:57 PM   #11
Joe Immler
That is kinda what i thought. Thanks for confirming itslow
Old 11-02-2017, 01:03 AM   #12
pooch
pooch's Avatar
You could summon him up at a seance........
pooch is offline   Reply With Quote
Old 11-02-2017, 08:53 AM   #13
tubman
tubman's Avatar
I was sorting trough some of my stuff yesterday and came across a set of Iskendarian 185G valve springs unused in the original box. They were painted gray if anyone cares.
Old 11-02-2017, 09:43 AM   #14
RalphM
RalphM's Avatar
This gets me thinking. If springs were powder coated, would the heat effect the spring tension?
Old 11-04-2017, 04:02 PM   #15
itslow
itslow's Avatar
The temperature required for powder coating is not high enough to adversely affect the spring. That said, it'd be unnecessary for a valve spring and could be damaging if the cured powder were to flake off and infiltrate the oil system.
Mike
Wanted:
- ARDUN parts
