Old 11-27-2010, 05:47 PM   #1
daredevilcustoms
Default What Model A Engine is this?
Bought this from a lady who was using it as yard art. I'm not familar with Model A engines (Model T guy). Can you help?
daredevilcustoms is offline   Reply With Quote
Old 11-27-2010, 05:56 PM   #2
John Stone
John Stone's Avatar
Default Re: What Model A Engine is this?
It just looks like a Model A engine. It might be a later replacement engine. Diamond block.
John
John Stone is offline   Reply With Quote
Old 11-27-2010, 06:26 PM   #3
Rem/Mo
Rem/Mo's Avatar
Is there a number stamped on a pad on the left side of the block just below the head gasket.
Rem/Mo is offline   Reply With Quote
Old 11-27-2010, 06:49 PM   #4
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
Tractor motor??? Note the idler pully
Rusty Homestead Fl is offline   Reply With Quote
Old 11-27-2010, 07:17 PM   #5
BCCHOPIT
BCCHOPIT's Avatar
good EYE
Is that way the oil tube looks so big
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 11-27-2010, 07:49 PM   #6
James Rogers
James Rogers's Avatar
The tube is a B tube. Might be a B motor but need to see the motor from both sides to tell.
James Rogers is offline   Reply With Quote
Old 11-28-2010, 11:58 AM   #7
daredevilcustoms
some additional phots, not a B engine. Serial # A4869984 and is a diamond block. I assume its' an industrial engine. What is the significance of the diamond blocks? Thanks
Old 11-28-2010, 12:17 PM   #8
Bruce Adams
Bruce Adams's Avatar
My late 1931 "A" engine has the fat (B?) filler tube.
It has no other items differing from the standard "A" engine.
Bruce Adams is offline   Reply With Quote
Old 11-28-2010, 07:47 PM   #9
Chris in WNC
Chris in WNC's Avatar
yard art?
any water inside it?
keep us posted on the condition as you get inside it.
Chris in WNC is offline   Reply With Quote
Old 11-28-2010, 08:22 PM   #10
daredevilcustoms
It still had oil in the crankcase, so I'm hopefull that the motor is good inside. Thanks
Old 11-28-2010, 08:52 PM   #11
midgetracer
midgetracer's Avatar
The diamond blocks were made after stock production ceased. Some theories are that they have thicker castings, but this is disputed often. The usual difference is that diamond blocks were often used in industrial applications and often have hard valve seats.
midgetracer is offline   Reply With Quote
Old 11-28-2010, 11:53 PM   #12
glenn in camino
glenn in camino's Avatar
Looks like a Model A engine with an aftermarket script head.
Old 11-29-2010, 01:18 AM   #13
sturgis 39
Default Re: What is ment by a diamond block
How can you tell a diamond block from a standard "A" block? Is there a diamond cast into the block or something? A diamond in the serial number?
Someone said industrial engines serial numbers do not start with an "A". Is this true? I heard industrial engines have different valve springs.
Let me know.
Thanks
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 11-29-2010, 01:31 AM   #14
Kohnke Rebabbitting
Glen, I think the early Model A's had them to about middle 1928, thanks Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 11-29-2010, 07:10 AM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
Let me know.
Thanks
Diamond engines had a small diamond cast in the block near the cam gear side cover.
I don't know about the serial numbers on industrial engines.
Old 11-29-2010, 09:24 AM   #16
Jerry Parr WI
Jerry Parr WI's Avatar
Complete engine assemblies for stationary engine use were serial numbered. They included all the accessories including starters, generators, etc. Engines for use in service were unnumbered, so an engine could be either way depending on the intended use.
Jerry Parr WI is offline   Reply With Quote
Old 11-29-2010, 09:38 AM   #17
Aerocraft
Aerocraft's Avatar
I have several heads identical to what is shown. They are Ford built heads cast after the A went out of production. Just in front of the water outlet you can see a date "tag" cast into the head. Gar Williams
Aerocraft is offline   Reply With Quote
Old 11-30-2010, 09:42 AM   #18
Tom from Drippin'
Tom from Drippin''s Avatar
[QUOTE=Is there a diamond cast into the block or something?
Thanks[/QUOTE]
See the second photo in post #7. the <> is horizontal.
The pursuit of excellence is healthy and rewarding.
The pursuit of perfection is frustrating, neurotic and a terrible waste of time.
Tom from Drippin' is offline   Reply With Quote
Old 11-30-2010, 12:32 PM   #19
Kohnke Rebabbitting
Gar, in the Model A Judging Standards, Copyright 1981, on page 1-1 at bottom Right, it says.
"Quote" Most cylinder heads had no Ford script and few, if any markings. Ford script heads are acceptable through mid 1928 only. After mid-1928, Model A cylinder heads had no numbers or letters on them. Other after market heads will appear identical to the factory original heads, except they may have raised bosses with numbers or letters. "End Quote"
Ford was real touchy about someone using the Ford name on after market parts. A good friend of mine who lived in Omaha, Mel Alexander also told me that those heads were Model A AR. So if that ford script is not Early AR, what do the Early AR's look like, as that head is the only Model A head style I have seen with Ford script. If I am mistaken, I would like to find out, I am going to keep digging in my Model A books, and see what I can find, give me some help Guys, see what you can find. thanks Gar, Herm.
Old 11-30-2010, 01:51 PM   #20
dave m
looks like orig painted yellow should'nt it be green if model a auto
dave m is offline   Reply With Quote
