I have a leakless water pump it's the type that the rear bearing needs to be greased. The instructions said to loosen the packing nut so the grease doesn't go into the coolant. So that's what I did. The question I have is how tight do I tighten the packing nut ? Do I make it finger tight or just tight enough to hold things together? I don't want to over do it it's a 1 year old pump
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
Just tight enough that the shaft spins easy and water does not leak out.
![]() If the seal is the lipped type/modern it does not matter where it sit on the shaft there would be the same amount of pressure on the shaft from the seal. OH! You don't need to over do the grease, a little goes a long way. ![]()
I know the voices aren't real but damn they have some good ideas! ![]() Last edited by redmodelt; 03-01-2017 at 01:33 PM. |
The one I got from Bratton's recommended removing the rear grease fitting altogether, packing grease into the housing with your finger, then reinstalling the grease fitting. This would ensure that you didn't force grease out under the seal into the coolant.
Using the correct water pump grease helps get rid of that issue, grease mixing with water.
I know the voices aren't real but damn they have some good ideas! ![]() |
Paul in CT |
You don't even need a separate grease gun. I use the cap on the fitting to push the grease in. Just scoop a little into the cap and screw it back on part way, then tighten some more a few hundred miles later. A little does indeed go a long way. By the time the cap is screwed all the way back on, you've done maybe 1,000 miles. The bush might take more grease as it or the shaft wears, which the soft shafts we are offered these days will do.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
In posts 4 and 5 the use of water pump grease is advised. However in the Ford Service Bulletins for September-October 193 2Ford dealer mechanics are warned against the use of special water pump lubricants for both the 4 cylinder and V8 cars advising that special water pump lubricants have a melting point considerably higher than the maximum water temperature, forcing surplus lubricant to ledge in the radiator water tubes. I know that advice was dated 1932. I have no expertise in the water pump lubricant sold today so I pose the question to posters 4 and 5 to clarify their statements. In 1932 the Service Bulletin went on to emphasize using chassis grease in the water pumps. Is there a lubrication expert in the ford barn forum??
x2 Barnstuff! my thinking too....I can understand why you'd want waterproof grease (aka waterpump grease) on say a boats underwater propeller shaft. But on a car water pump using w/pump grease isn't going to stop you forcing grease through into the coolant and once there the water pump grease is much more likely to clag the tubes by not dissolving like ordinary grease would.
Thanks to everyone for responding on my thread. But the type of grease isn't the problem. I understand that I should use water pump grease. I just wanna know how tight should the packing nut should be
I have one of those pumps on my car.My understanding is the nut is to be finger tight and only tightened in the event of a seal failure (water leak) to stop the leak to get you home.
#12 | |
![]() Quote:
That said, I will not have a bar of the so called leakless pumps being flogged by vendors. I consider them rubbish. I build my own with modern seals and a sealed ball bearing at the front. Far more durable and still have the nut and gland packing just in case. Haven't needed it yet.
