01-21-2017, 07:57 PM | #1 |
31 Ford Coupe how remove doors
do pins drive out from bottom or how stripping for repaint thanks
01-21-2017, 08:09 PM | #2 |
Re: 31 Ford Coupe how remove doors
yes the pins drive out from the bottom. you are better off using a pin press and push them out. if you drive them out, the pin needs to start moving right away or you will mushroom the end of the pin. and they are the sh-t`s to drill out.
I`m not fallowing the stripping. |
01-21-2017, 08:16 PM | #3 |
Depending on what you have (rust , needing blasting etc,) you may want to leave them . As John said the puns can be difficult to deal with.
I just painted a body today I decided to leave the doors on...glad I did. All the rest if the time I have taken then off . If the don't come with a little heat and persuasion as John indicated you will have to still then out. I prefer to drill half way and try to drive out the weakened pin ...many times that does it Best of luck Larry |
01-21-2017, 08:20 PM | #4 |
Capitals, commas, and periods go a long way to make sense of what is being said or asked. Yes, the hinge pins are driven upward from the bottom. Soak them with Kroil and open and close the door to work the Kroil in, then try to tap the pin up.
I've had to grind the round head off, then drill down about 3/4 of the way, using a bit just smaller than the pin diameter, then use a punch to push the pin down and out. I've had limited success using the hinge tool, but it's worth a try first. |
01-21-2017, 10:38 PM | #5 |
What I did on my L31 Tudor, heat and penetrant oil and after 4 hours fighting I needed a break! I then went and walked around the tractor suppy looking for help. In the tool section there was a bigger hammer than me. I was using a pin punch and a 32 oz hammer that had tried me out. A air hammer set for less than 20$ is what I purchased. I ground down a set smaller than the door pin to push the pin out. I pulled the trigger and the pin jumped out flying up about 4 feet. I finished removing the pins in about 10 min of work as compaired to 4 hours of frustration. Tap tap don't force it get a bigger hammer :-)
01-22-2017, 05:19 PM | #6 |
Of course, what method you use partly depends on if you are trying to preserve the paint. It might also be a good time to consider if you want hinge pin mirrors. Last edited by 5window; 01-22-2017 at 05:32 PM. |
