03-09-2017, 09:21 AM | #1 |
Manifs\d gasket
Can someone tell me which way the copper gasketshould go between the exhaust manifold and exhast pipe. Should I use muffler sealing paste also?
If I can't get the gasket to seal can I use muffler paste alone? Thanks Bill G |
03-09-2017, 09:42 AM | #2 |
Re: Manifs\d gasket
The metal, if one side only, goes towards the hotter exhaust manifold.
03-09-2017, 09:46 AM | #3 |
Re: Manifs\d gasket
I would check both the manifold and engine for the sealing surface for flatness! Brattons one piece gasket, they say metal side towards manifold! If both surfaces are flat, no sealer would be needed. Hope this helps.
03-09-2017, 09:52 AM | #4 |
Re: Manifs\d gasket
I believe he is referring to the pipe to manifold, in which case I would just use muffler sealer, if that still leaks then the insert should be installed.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
03-09-2017, 10:11 AM | #5 |
Re: Manifs\d gasket
I think Brian is right about the question referring to the pipe and not block to manifold. I don't use anything, but I have an Aries stainless, so the fit is good.
03-09-2017, 10:53 AM | #6 |
Re: Manifs\d gasket
03-09-2017, 11:24 AM | #7 |
Re: Manifs\d gasket
When I was still evaluating my Double A, I spent much time repairing things before buying new or good used parts, I spent over an hour filing that manifold set and cleaning up the header pipe using the muffler sealant.
It did sound sweet when I installed a new manifold and Aries muffler though.
