04-07-2020, 08:33 AM | #1 |
1929 Sport Coupe speedmometer
New to Model A's. My speedometer is bouncy, sometimes it is steady but most time not. Is this normal?, or is there a problem. Thanks in advance.
04-07-2020, 08:56 AM | #2 |
Re: 1929 Sport Coupe speedmometer
It could be a cable that is kinked causing some drag and twisting or it could be a problem with the bearings in the speedometer. If the drag cup is catching on the magnet rotor then it will cause your symptoms. The magnet rotor has to spin inside the drag cup without any contact and loose bearings can cause contact.
04-07-2020, 09:31 AM | #3 |
It's a floating kind of bounce it does not jerk as if there is a kink
04-07-2020, 10:22 AM | #4 |
The first thing I would di is clean and regrease the speedometer cable (inside the housing).
04-07-2020, 10:54 AM | #5 |
Mark in MT Always looking for another opportunity to be wrong. |
