Old 05-16-2014, 08:41 PM   #1
Colonel
Default Wiper swipes onto Windshield Frame
Have a vacuum wiper on my slant windshield sedan. It works very well but the swipe of the blade travels onto the windshield frame and when it returns ends up a bit on top of the windshield frame also. I verified with others that I have the correct arm and blade. Is there an adjustment I can make to keep the wiper blade on the windshield as it goes through its cycle or... is this normal?
Colonel is offline   Reply With Quote
Old 05-17-2014, 07:42 AM   #2
Growley bear
Default Re: Wiper swipes onto Windshield Frame
Not normal.
Growley bear is offline   Reply With Quote
Old 05-17-2014, 09:04 AM   #3
Randy in Illinois
Randy in Illinois's Avatar
Hi colonel, i have a 31 coupe that i had the same issue . I found the wiper arm bends are slightly off. Where it connects to the motor.Just bend the wire wiper arm allittle at a time more or less to adjust. It takes alittle trial and error Before you get it right.
Randy in Illinois is offline   Reply With Quote
Old 05-17-2014, 09:12 AM   #4
FL&WVMIKE
FL&WVMIKE's Avatar
There is no adjustment.
Try a shorter blade,
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
