Old 04-14-2014, 03:37 AM   #1
Ray Balukas
Ray Balukas's Avatar
Default Lower & upper Radiator Hose Help 37 Panel
Does anyone have a Lower radiator hose part No for 37 Panel with 8BA 37 radiator. They are about 6 " long with a slight curve to them. Any help would be great. Also I might as well ask about the upper hoses for the same. Thanks Ray
Ray Balukas is offline   Reply With Quote
Old 04-15-2014, 09:05 AM   #2
Ray Balukas
Default Re: Lower & upper Radiator Hose Help 37 Panel
Help please! Ray
Old 04-15-2014, 03:26 PM   #3
Chris Nelson
Chris Nelson's Avatar
Ray; The auto parts stores have hoses of all different shapes, lengths and sizes. I have purchased hoses for another type of car and used only a part of the hose. Kind of a cut and fit. The last one I did, I only used the center of the hose and threw away both ends. Sometimes we have to adapt if an original is not available.
Chris Nelson is offline   Reply With Quote
Old 04-15-2014, 05:08 PM   #4
Ray Balukas
Thanks Chris, I have the hose that I took off, that's what it looks like was done. I will do that if I can't get help from someone who has the same setup. Thanks again Ray
Old 04-15-2014, 05:23 PM   #5
Mart
Mart's Avatar
Ray, as yours is a non standard application, (8BA) you are the only person that has the means to find the right hose (or part of a larger one). Macs list the stock hoses for pickups (I guess panels are the same) at 6" long and look straight in the pics. If these would not do the trick you really do need to walk into the most helpful parts store with your old one in hand and see what they can do for you.
Mart.
