Old 03-21-2013, 04:45 PM   #1
pooch
pooch's Avatar
Default Joey box
http://www.ebay.com.au/itm/151014095...=p5197.c0.m619
A Henry Ford designed overdrive.
Was a factory shortened tailshaft made for this?
pooch is offline   Reply With Quote
Old 03-21-2013, 04:55 PM   #2
James Rogers
James Rogers's Avatar
Default Re: Joey box
it appears to be a high/low box for a AA truck.
James Rogers is offline   Reply With Quote
Old 03-21-2013, 04:58 PM   #3
kingbee
kingbee's Avatar
Send a message via AIM to kingbee
Did you notice it's actually an underdrive?
kingbee is offline   Reply With Quote
Old 03-21-2013, 05:14 PM   #4
Joe K
Joe K's Avatar
"Dual High" so named in marketing hubris of 1928. Actually more a "dual low."
The AA truck might get 42 mph with a high speed rear end. Give that maybe 32 mph with the dual low engaged.
I don't want to talk about a low speed rear with a dual high.
Joe K
Shudda kept the horse.
Old 03-21-2013, 09:40 PM   #5
columbiA
To install the Dual High aux trans in the 28 AA,the coupling shaft assy was removed & the aux trans was installed in its place.It just gives you a slow & slower speeds-great for pulling very heavy loads.A much better choice would be an AA Warford 3-speed aux trans which gives you an under,direct & overdrive.It also fits in place of the coupling shaft
columbiA is offline   Reply With Quote
