Old 02-25-2021, 05:09 PM   #1
HDowse
HDowse's Avatar
Default Rear axle key orientation
I pulled the rear drums on the '29 coupe a few days ago, cleaned everything up but I forgot to check how the axle key fits back in the axle groove. I have the ones Snyder's sells with the somewhat elongated bevel. Going to write it down this time.....inside the drum...
HDowse is offline   Reply With Quote
Old 02-25-2021, 05:17 PM   #2
kwisor
kwisor's Avatar
Default Re: Rear axle key orientation
the tapered end faces down (what you are calling the elongated bevel) and facing the backing plate. be sure the it is at the end of the shaft out side hub will go on easier i just finished doing my brakes.
kevin
kwisor is offline   Reply With Quote
Old 02-25-2021, 06:10 PM   #3
HDowse
HDowse's Avatar
Thanks, Kevin, that makes sense since the key way tapers up towards the backing plate end. Now I can put everything back together....
Old 02-26-2021, 09:40 AM   #4
kwisor
kwisor's Avatar
you are welcome did you get them on
kevin
Old 02-26-2021, 07:03 PM   #5
HDowse
HDowse's Avatar
Yes, they went on just fine this afternoon, thanks.
