07-17-2016, 05:41 PM | #1 |
Speedo works backwards
speedo show forward speed only in reverse, and bottoms out in forward gears. i just now got the speedo cable installed for the 1st time since ive owned the car. its a 42 fordor with a 47 rear end. the turtle will only mount in one direction and allow me to install the cable. if i install it reversed to how it is now I have to cut a hole in the frame.
will reversing the way the turtle mounts make the speedo work correctly? |
07-17-2016, 06:39 PM | #2 |
Re: Speedo works backwards
I think you must have the torque tube clocked wrong to force such a mounting of the turtle. Easy check, the center zerk fitting should be straight down at 6 o'clock.
Alan |
07-17-2016, 06:54 PM | #3 |
Is the turtle mounted so that the cable attaches to it on the bottom?
Who had the torque tube out? I am wondering if the driven gear - at the end of the driveshaft, was installed backward. Would that make the speedo run backward? Maybe someone else can answer that with 100% certainty. I think it would but am not entirely certain.
07-17-2016, 06:57 PM | #4 |
If the torque tube was installed wrong then the radius rods wouldn't mount to torque tube as they should. The mounting point for the radius rods is also on the bottom???
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
07-17-2016, 06:57 PM | #5 |
07-17-2016, 07:05 PM | #6 |
Torque tube has the e-brake cable mount welded on, on the bottom of the tube. Now, for my statement I have to drill a hole in the frame -- well it darn sure looked like i would. After flipping the turtle and reinstalling, the cable passes between the frame and a floor support. I took the turtle off and checked rotation of the cable drive based on mount and sure enuf, rotation changes if you flip it, so I did, speedo works now. |
07-17-2016, 07:07 PM | #7 | |
07-17-2016, 07:14 PM | #8 |
Thanks for the update.
07-17-2016, 07:38 PM | #9 |
I guess I'm just goofy. This is the first major undertaking I have done and every time I have success with something I feel like a kid and have to share it with someone.
The picture are how it sits today. but still way far from being "done" if it is ever done. |
07-17-2016, 07:43 PM | #10 |
Good job and nice car - gotta love those rare '42 Fords
07-17-2016, 08:26 PM | #11 |
i love the delivery sedans.
i like stuff no on else has. when i finally go down the road I want people to know who it is because of what it is. I have not seen another 42 around here. These pics are how it was when I brought it home |
07-17-2016, 10:18 PM | #12 |
Looks like you've done a great job on it!
07-17-2016, 10:43 PM | #13 | |
That is exactly why I have my '42's. I also have a Fordor Ex-army staff car to do one day if I don't run out of time that is
