09-27-2023, 06:58 AM | #1 |
Loosen Head Nut
In this reply, an ignition cable clamp mod is suggested. https://www.fordbarn.com/forum/showp...27&postcount=8
Not to knock Bob's tip, but how risky is it to loosen that nut, regarding later head gasket problems? I'd like to do it, but I have a washer under the nut now and not enough length for the single clamp ear and a jam nut, without removing the washer. |
09-27-2023, 07:17 AM | #2 |
Re: Loosen Head Nut
Lower the coolant level below the head ( I would just completely drain the coolant) then remove the nut do your work reinstall and re- torque the nut. You should be ok
09-27-2023, 07:31 AM | #3 |
Re: Loosen Head Nut
The clamp on the ignition cable was used in 1930 as a theft deterrent. In 2023 it does not make much sense. Unless you are going for points, leave the clamp off and just let the cable rest on top of the head.
09-27-2023, 08:07 AM | #4 |
Re: Loosen Head Nut
I've seen guys claim that they did a quick repair using that nut and there was no effect. However, the entire risk can be mitigated by draining just enough coolant to fill a gallon milk jug, so if you're doing the operation in your garage it seems like it would be prudent to go ahead and drain.
09-27-2023, 08:23 PM | #5 |
Re: Loosen Head Nut
I once had a head stud pull out of the block. I had to drive about 20 miles to a friend's workshop to fix it which I did without hesitation.
On another occasion, another friend drove 800 km home from a National Meet through some very hilly country with the same problem. He was disbelieving when I told him he would get home easily. He was a believer when he made it with no issues. Merely loosening the nut, then retightening it - don't over think it.
09-27-2023, 10:03 PM | #6 |
Re: Loosen Head Nut
09-28-2023, 04:25 AM | #7 |
Re: Loosen Head Nut
Sounds good, I'll go for it! Thanks to all.
