06-13-2019, 11:13 AM | #1 |
Battery Cables for a 1948 flathead 6
Where do you find good quality battery cables for a 1948 flathead 6 cylinder. 6 volt system.
I believe there are 3 that need to be replaced. Vendors aren't very clear as to what gauge and size they sell. I would like some replies from people who have actually bought them and used them with good results. I also believe they should be 00 size, is that correct? Thanks. Last edited by gtdohn; 06-13-2019 at 12:18 PM. |
06-13-2019, 11:27 AM | #2 |
Re: Battery Cables for a 1948 flathead 6
Use "O" ought or at least "OO" double ought. Try a semi truck parts/repair shop or maybe even a welding supplier, they will have the wire and you can supply the ends and have them sewage the ends on for you. Assuming 6V system??
06-13-2019, 12:51 PM | #3 |
I bought replacements from Rhode Island Wiring and have been very satisfied. They are the proper gauge and length with correct insulation and terminations.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
06-13-2019, 03:50 PM | #4 |
