04-21-2016, 01:05 AM | #1 |
Mystery Firewall Hole
My 48 super deluxe coupe has a hole in the firewall with no plug, can't figure out what it is used for, should I just plug it up? See photo for location, its the hole between the two wires
04-21-2016, 03:01 AM | #2 |
Re: Mystery Firewall Hole
maybe there was a heater installed some time....
04-21-2016, 11:31 AM | #3 |
There STILL IS a heater installed........look to the left! DD
04-21-2016, 12:07 PM | #4 |
On trucks that's where the speedo, choke, and throttle cables come thru.
'52 F-1, EAB flathead |
04-21-2016, 03:29 PM | #5 |
Must be another 46-48 Ford you can look at at a show?
04-21-2016, 03:42 PM | #6 |
04-21-2016, 03:45 PM | #7 |
The light blue one is a 41 and the maroon one is a 42.
04-21-2016, 10:08 PM | #8 |
where did find the grommet for the 41?
04-21-2016, 10:44 PM | #9 |
Actually my '41 heater doesn't have tubes located in that position(stock 41'48). Mine are about where the lower left tube is and about where the knockout remains below the hole between the wires.
