Marvel Carb Hi, Does anyone have the float setting for the square bowl Marvel carb that can be used on a Model A?
Got one at the Turlock CA swap meet and want to try it out. Thanks |
Re: Marvel Carb Separate top & bottom of carburetor.
Turn top part of carburetor upside down. Gently adjust float height such that the float will rest parallel with the joint/gasket between top & bottom part of carburetor. |
Re: Marvel Carb Thank you.
