The Ford Barn
-   -   Period Correct Exhaust Build (https://www.fordbarn.com/forum/showthread.php?t=96523)
1962300 02-03-2013 12:12 AM
Who does what?
I am building a late 1940's style 1932 Roadster...with a Flathead and dual 97's.
I need to design the exhaust.
I have Red's Headers to start. (not as period correct as making my own, I know)
I am interested in knowing what anyone may have done to create a Period Correct Exhaust from the Headers on back...
- All pipes slip fit?
- System held by hangers and not welded to frame
(Anyone sell vintage style hangers?)
Thanks!
uncle max 02-03-2013 09:54 AM
Re: Period Correct Exhaust Build
All welds should be made with coat-hangers and a torch. ;)
trainguy 02-03-2013 10:01 AM
How about using that fexible pipe they used back then!
trainguy 02-03-2013 10:02 AM
flexible
JonC 02-03-2013 10:16 AM
Don't forget your tomato soup cans for minor repairs
51 MERC-CT 02-03-2013 10:17 AM
There are probably dozens of "period correct" ways of doing it. All depends on which way you want it. Maybe something like this.
http://i11.photobucket.com/albums/a1...rzr/header.jpg
BILL WZOREK 02-03-2013 10:18 AM
trainguy,
Not criticizing but if you go back and click on to your own post in the lower right cornor there is a edit button that allowes you to go back and edit your post for spelling or whatever reason. it has to be you post though.
qmdv 02-03-2013 10:42 AM
My dad was born in 1918 and this pic was taken before 1941. Had to be between 1938 and 40. Notice how the tail pipes were hung from the rear bumper on his 32 3 window. That is period correct.
http://i687.photobucket.com/albums/v...v/SCAN0047.jpg
And where you going to get duds like my dad was wearing. Notice the Road Rebel plate on the back. A Los Angelos club.
Tim
37 Coupe 02-03-2013 12:42 PM
They use to put V8 tomato juice in a can that seemed to be just the right size and a heavier guage,this was pretty technical stuff . I think I used at least one of these to fix the damage done after installing the dash controlled exhaust cutout from JC Whitney that invariably would not completely shut and leaked.
Walt Dupont--Me. 02-03-2013 01:27 PM
Me and a couple of my buddys when we were 16 jopped a 32 5w and welded it all back together with coat hangers. My mother always wanted to know what happened to her coat hangers. Walt
BrianCT 02-03-2013 03:08 PM
Tim
Notice that they run beneath the axle . Makes for some clunks when crossing
RR tracks.
PeteVS 02-03-2013 04:05 PM
Detonator posted this picture last month. It was his uncle's car and the thread was "Show us your avatar" or something like that. Doesn't get too much simpler than that!
http://www.fordbarn.com/forum/pictur...ictureid=18860
Here's a link to the thread:
http://www.fordbarn.com/forum/showth...atar&showall=1
1931 flamingo 02-03-2013 04:15 PM
Who remembers the 'scavenger" pipes of the 60's?? Welded them to the 6 cyl chev mufflers (deuce coupe with an olds),flex pipe at the front off stock exh manifolds. duals, gave a "strange" sound.
Paul in CT
Mart 02-03-2013 05:33 PM
My 33 had the remnants of pipes still in place. there was flexible pipe in there, the mufflers were mounted straight to the floor and the remaining tailpipe was mounted off the frame.
If that's period correct I'd rather do it a little more carefully and at least get some rubber in there.
When I did do mine I made it up from an exhaust meant for another car and I did gas weld it, so maybe it is still kinda old school.
Mart.
trainguy 02-03-2013 06:11 PM
Originally Posted by BILL WZOREK (Post 584277)
trainguy,
Did not know that,Thanks Phil
ford38v8 02-03-2013 06:16 PM
Run a pair of torque tubes under the axle. Pennies in the crossovers, no mufflers.
Hoo Yah! Rumble like ya mean it!
Bassman/NZ 02-03-2013 07:30 PM
Dont forget ripple pipes! Just heat and bend, the ripples actually look quite cool.
Pete 02-03-2013 07:36 PM
All water pipe with screw fittings. Very stout.
Lucky Mike 02-03-2013 07:52 PM
1 Attachment(s)
Use 1934 drive shafts....you will never get a better sound. That is what I have on my car.
49r 02-04-2013 01:48 AM
x2. That's how I did it in the 1970's.
