Question For The Engine Experts 1 Attachment(s)
I pulled my '40 engine out to freshen it up. I'm seeing something I've not seen before, regarding the rear main bearing. The upper half of the bearing (inserted into block) has a groove machined perpenticular to the main oiling groove, extending towards the back of the black. There is a very small hole, which apparently was included to allow oil into this groove.
Anyone ever seen anything like this before, and what would be the purpose? Joe |
Re: Question For The Engine Experts After the third time heavy foot Al burned up the clutch they made him a special clutch with shimmed springs, after the third time he burned up the thrust they made sure it got enough oil
Re: Question For The Engine Experts Quote:
Joe |
Re: Question For The Engine Experts Joe
That main bearing was made by Ford for heavy clutch use in busses etc. It provided additional lube oil to the rear thrust face. The part number was 81B-6331-whatever undersize letter. The ones I have seen from Ford had a hand scraped area were yours had the groove cut. Also no lube notchs cut in the thrust faces. Hope this helps. Gary |
Re: Question For The Engine Experts Thanks Gary.....I guess that makes sense. I'd just never seen anything like it before, and wasn't sure if it was a factory bearing or something someone fabricated for some reason.
Joe Quote:
| All times are GMT -5. The time now is 10:32 PM. |
