The Ford Barn
-   -   Staying Cool in the Heat? (https://www.fordbarn.com/forum/showthread.php?t=79049)
Brobrian 08-06-2012 07:16 PM
Been a few discussions on radiators and cooling lately. Today I made my commute in 103 degree heat. Truck ran cool(ish) in traffic and on the road. For me it's the result of a repro radiator, a fresh flush, and a fairly good running engine.
So, how you doing in the heat?
TinCup 08-06-2012 07:22 PM
Re: Staying Cool in the Heat?
107 yesterday and with a 3 core Bergs radiator ran 180 without a hitch.
eagle 08-06-2012 09:40 PM
Pushing 90 here and runs as cool as ever. I've never had mine really get hot. I check the coolant now and again, put in a couple cups after a year. In a parade, running with the RPMs as low as she goes, there is a lot of heat in the hood, but never overheats....Yet.....
Brobrian 08-07-2012 07:43 AM
Supposed to be between 105 and 109 all week here. If both my A's run cool and leak-free I'm considering switching to that Evans waterless lifetime coolant. Saw it on an episode of Jay Leno's Garage on YouTube and was intrigued. The idea of a coolant that doesn't boil in an unpressurized system and thus won't mess up my hood, and will never corrode my engine seems too good to pass up.
30ccpickup 08-07-2012 08:06 AM
Here is the link to Jay's video on Evans's coolant.
http://www.evanscooling.com/
Paul
Frank Nemo 08-07-2012 10:43 AM
Has anyone tried it in their Model A and what was the result? For those of us in the Northern tier of states where freeze protection is a concern, I understand (from the Evans web site) that their coolant in the cold thickens but never expands or gets solid. A very interesting concept.
TinCup 08-07-2012 10:59 AM
One of our local club members bought a car out of Arizona that had this installed. It works fine as long as you have a good radiator. His radiator was bad and after we changed it out he went back with a 50/50 mix water and antifreeze. He didn't want to pay the extra money for the Evans.
Brobrian 08-08-2012 05:11 PM
102 in the shade today! While the radiator worked well (no motometer so no precise temp), I started vapor locking while in the stop & go through town. Just pulled down the throttle lever so the engine was well above idle the whole time and made it through ok. If it hadn't been for that thread on the Barn where a guy videoed the fuel turning to vapor in a clear gasl line I would not have understood to keep the flow of fuel up and the vacuum high. As it was I just got a few funny looks from folks who heard the engine revving at stops.
sconnors 08-08-2012 06:11 PM
I recently did the following and are seeing some good results:
1. Ran distilled white vinegar for a week and flushed out the system - this worked wonders!
2. Ran 1 Gallon of Simple Green and distilled water for a week and flushed the system. The only thing you have to be careful of here is that if Simple Green shoots out of the motometer/radiator cap it stains your paint and is a pain to get off.
3. Exchanged to motometer for a plain old radiator cap and gasket
4. Bent the overflow tube back as suggested in these forums and the Service Bulletin
5. Filled with distilled water
Today it was in the 80's here and I ran her for quite awhile up some pretty steep hills and not a drop out of the cap or the overflow tube. The vinegar worked great and got a lot of rust and crap out but make sure as others have said that you drain it in a bucket because it will stain your concrete.
Logan 08-08-2012 06:58 PM
110 degrees sitting in traffic, with the a/c on running 175 when driving it was about 170 because I have a 170 thermostat in it. I have a modern core, 3 row pressurized radiator. It's well worth the money
Duffy1 08-08-2012 07:05 PM
Logan ;
What lb radiator cap do you use ? Also when you pressure up the radiator does it cause leaks else where ( head gasket ,water pump , etc. ).
Thanks
oldmanandakid 08-08-2012 07:46 PM
I would be interested in knowing how many of you hot weather drivers have engine pans installed.
TinCup 08-08-2012 08:05 PM
Is this the radiator that Ken Davis showed me that someone in the dfw area was making up?
Logan 08-09-2012 01:59 AM
It probably is, I know his and and him have bought one or two. Al's radiator shop is the name of it.
Logan 08-09-2012 02:00 AM
I do not use engine pans
Brobrian 08-09-2012 06:36 PM
My coupe is sans pans, but the pu has them. As for cooling, the pu ( with the pans) runs hotter in the engine compartment than the coupe. But it would be crazy to conclude from that that pans cause the heat to build in the engine compartment. I'd have to run bith cars with and without under similar conditions to measure any effect.
V4F 08-09-2012 06:40 PM
108* the other day . went to car show ........... ran 160* all the time (160 thermostat)
