1928-31 Fordor help Okay, so now I have a 1931 Fordor body that has no sub frame. Searching high and low for a supplier that sells a sub frame for this body. I’m told [by a guy at work] that all 1928-31 Fordors has a wood sub frame, since these bodies were not made by Ford, but by Murray & Briggs. Is this true? Since I need to fabricate my own rails, I’m thinking of using 1” x 3” or 1” x 4” rect. Tubing. If I go this route, how thick? Also where can I locate dimensions for a fordor sub frame? Thank you, thank you, for any direction on this.
Re: 1928-31 Fordor help Your friend at work is right wood sub frame, and wood around the doors ,
Bratton's sells a sub frame kit for it look under wood parts. it's not cheap but it's a lot of wood!!!! John |
Re: 1928-31 Fordor help Do you have an EARLY or LATE '31 body. If it is a Slant windshield... there is no wood subframe..it's all steel.If you know if is Briggs or Murray body Classic Wood Mfg 1006 N.Raleigh St. Greensboro NC. 27405 Tel 336-691-1344 Can provide a catalog that has listed any piece of body wood that you may need. Excellent Quality.
No I'm not an employee...just a very satisfied customer. Bruce Davis [email protected] |
Re: 1928-31 Fordor help It's the standard 155-C Murray body
Re: 1928-31 Fordor help That's the info you need if you decide to order a catalog from Classic Wood.
Re: 1928-31 Fordor help I'd just like to find a drawing somewhere, so that I can make my own...
Re: 1928-31 Fordor help 2 Attachment(s)
Each piece that you need plans for is at the Bensen Research Center in Dearborn. Making your own is not that difficult, ...just time consuming. . |
Re: 1928-31 Fordor help Quote:
Re: 1928-31 Fordor help Brent....one important factor...some people have knowledge and talent...and many think they do !! I can relate to my experience in judging. I could spot homemade top bows from twenty feet..three times I was wrong because the restorer had TALENT & KNOWLEDGE.
