Coil ohm rating?.... Is the stock Model-A ford 6 volt coil ohm rated at .6 ohm? If a stock
Model-A has been converted to 12 volt would a .6 ohm 12 volt coil work? I tried to search the info but could not find it in the archives. TIA:) AMF/Bob-A:D |
Re: Coil ohm rating?.... For an internally resisted coil for use on the model A, you will need 1.5 ohm for six volts and 3.0 ohm for twelve volts
Re: Coil ohm rating?.... Mr. Swoft, I have sent you a PM. Bob-A
Re: Coil ohm rating?.... Mr. Bob I have returned your PM.
