The Ford Barn
-   -   What speed will I be able to get from a stock 1936 flathead? (https://www.fordbarn.com/forum/showthread.php?t=50470)
throwback 10-15-2011 07:53 PM
I wanted to know what speed I will be able get from a standard fresh rebuild with standard Crank and standard cam 1936 Flathead engine?
Thanks
throwback 10-15-2011 07:54 PM
Re: What speed will I be able to get from a stock 1936 flathead?
The Pistons are 3 1/16 dome type.
estout81 10-15-2011 08:16 PM
Probably 80-85 MPH.:rolleyes:
Tinker 10-15-2011 08:21 PM
Just a thought, but top end speed is relative to transmission and rearend gear sets.
The 20s- some 60's 3-4 speed transmissions, top gear is 1:1. That is where you end. Add an overdrive and 80 is obtainable and sustainable.
Brendan 10-15-2011 08:47 PM
i can go 50 in my 36 pickup with 411 gears
throwback 10-15-2011 10:38 PM
With a stock 36 flathead what transmission do you recommend and acceleration for city driving is also of importance, what rear end gear ration do you recommend?
Thanks!
tiquer 10-15-2011 10:48 PM
Thanks!
Don`t worry if you are light on the throttle the rest of the traffic will be able to keep up.:D:D
34coupe 10-15-2011 11:22 PM
Call your local old car club,have someone give you a ride in a stock 36, Dave
danliveshere 10-15-2011 11:31 PM
How fast do you want to go with mechanical brakes and rag tires?? Great advise to join up with a car club and see for yourself, but if you do alot of city traffic and also go down the interstate, then you may want to install a columbia or mitchell overdrive.
40 Deluxe 10-16-2011 03:02 AM
Buy or borrow a GPS unit, find a straight, level stretch of road, and have at it! Accurate, real-world, first-hand results!
JM 35 Sedan 10-16-2011 05:29 AM
I have taken my '35 sedan up to 75 and I know I could have gone faster but didn't care to. This was with a rebuilt 030 over engine, stock 3 speed transmission, 4.11 rear and 750x16 rear tires. I usually run ~ 60 on the interstates. Most want to pass me but many just keep pace with me to check my car over.
throwback 10-16-2011 07:30 AM
Thanks all that replied. The engine is at the machine shop. I was wanting to know the speed the engine is capable of and what transmission and rear end would produce the best results. The mechanical brakes are a concern when driving in city traffic. I will probably use juice brakes or discs for higher confidence of stopping.
Thank You!
jimTN 10-16-2011 08:02 AM
3:78 rear gear is best for all around running, will allow highway speeds.
Brendan 10-16-2011 08:55 AM
1 Attachment(s)
i still have mechanical brakes, and i drive my truck as much as i can, i drive alot in the city and take back roads, and have gone over some steep hills, hear in California i can drive my truck most of the time. i don't drive in the rain. make sure that you have good tires and your brakes are adjusted good and you have no play in your brake rods, and cross shaft.
Brendan
Ol' Ron 10-16-2011 09:31 AM
Depends on how hi the hill is.
Brendan 10-16-2011 09:55 AM
Hopland grade in lake county to Mendocino county , climbed in 2nd and down the other side in 2nd had to have my hand on the shifter to keep her from popping out od 2nd, i went 20 mph all the way
Charlie ny 10-16-2011 10:01 AM
TB,
With a 3:78 rear gear and a fresh 21 stud motor my '35 2 door
would do 75 all day with a Stromberg 48.....little things start to add up
like for instance compression ratio...how much have the heads been cut,
condition of the carb and dist.
Charlie ny
Barry-ct 10-16-2011 02:15 PM
Why go so fast and miss all the things along the way............. My 50 F-1 has 3:92 gears in it and that's fine. It wasn't built for interstate use and I'll stay on the secondary roads and enjoy the ride.
Bruce Lancaster 10-17-2011 03:56 PM
Ford actually had a spec for this!
There is in the Service bulletins a section on performance testing...it gives acceleration, top speed, and mileage standards for the dealer to use if a customer complained about any of these things. If the car met the standard, they could essentially tell the owner he needed driving lessons. If the car failed...the dealer needed to get to work!
From the August 15, 1938 bulletin: They lump '35 and 6 together in some columns, give '35 only in others...
With 4.11 rear the thing needs to be able to go 84.5 MPH and give 15.6 MPG on a Zenith Mileage tester to pass muster at the dealership. With that gear there is a huge drop in mileage between the 40 and 60 MPF columns!
PeterC 10-17-2011 05:09 PM
Bruce - 85MPH with a 4:11 seems unrealistic for any sort of distance - would you know the RPM that would require assuming stock tire/wheel combo?:confused:
