Just got Daves Model A, from Lincoln, Ne. done, lots of pictures If any body would like to see them, Hit my name,
Hit Profile Hit Show All Albums |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Nice Work!
I've heard of a story in pictures, but you just did a novel in pictures.:D I'll bet taking all the pictures and downloading them took longer than the engine rebuild.:D I was surprized by the small cam gear timing mark from the factory. I hadn't seen that small a mark before and can now understand why some need to be enlarged a bit to make them easier to find when timing an assembled engine. Also, the clutch disc surprised me, as I thought everything sold today had the spring center.:confused: Thanks |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Thanks, for posting.
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Great job. Here is the link for those that have not gotten the hang of how to get there as I know there are afew. Rod
http://www.fordbarn.com/forum/album.php?albumid=1352 |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Makes it easy to see why everyone says good things about your work.
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures WOW!!!! Thanks for sharing.
Paul in CT |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Herm,
Never gave this much thought until now. Were those a matched set of rods? Did you weigh the rods before pouring? I have turned the big end in a lathe, with a mandril to lighten the big end. And NO, I'm not trying to start something, just thinking, one engine guy to another. Dudley |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Thanks for sharing the pictures with us!!
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures So jealous, wish I rebuild my engine, so clean at all, thanks for postings the pictures!!
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Thanks for the pictures. For a guy like me that knows nothing about this sort of thing, this was very educational. Also for guys like me, it would be a great educational tool, to have a short narrative about what you are doing. But I also realize there are many of you that know exactly what he is doing and this would be a waste time.
Thanks again for showing what is done to an engine. |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Quote:
The time gears have been coming to small for years, but this is the smallest one I have ever seen. I think they just marked it so some one else would finish it, like no slots in the pistons, the factory told me I could finish them, I said, no I will just use another companies Pistons. The parts were not ordered by me, so that is how we ended up with a clutch disk without springs, I have never used one of these before, as once in a while, the old engines we took apart, they wern't in to good of shape! Thanks Tom, Herm. |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Herm : my compliments, this is the way to go , clean workshop , clean workbench and machines, clean tools, and ..working with clean hands also. That's the way I work on my car. It pays of. Again my compliments.
Gerard |
Thanks D.J., Herm |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Nice work Herm. You do not see work that good to much now days.
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Thanks for all for nice comments, it means a lot comings from all you Guys, but like D.J., and Tom, if you got any Questions, ask away. I am sure there are many things done differently then what you have seen there. Thanks Herm.
Thank you for the information. Would you explain " spun poured " vs what ever other type of pouring and how it's done? Thanks again, Dudley |
Re: Just got Daves Model A, from Lincoln, Ne. done, lots of pictures Kohnke, in the photo with the front pulley in the lathe, are you cutting the seal surface undersize for a particular seal that is available, or are you thinking a few thousands of a cut won't make any difference with a standard size seal?
Loved your comprehensive photo essay a great contribution to the rest of us. I am surprised in your method of weight removal on the caps. It seems very labor intensive. Would it be feasable to remove enough weight from the rod studs by grinding? You could protect the bearings against contamination. Just wondering if there is enough length to remove as much weight. Again, thanks for all of us for your efforts. |
