The Ford Barn
-   -   Fuel gauge float question (https://www.fordbarn.com/forum/showthread.php?t=49022)
sethkestenbaum 09-29-2011 02:07 PM
Does one need to remove the fuel gauge from the instrument panel to replace the cork float?
RonC 09-29-2011 02:23 PM
Re: Fuel gauge float question
yes. Buy the good steel tools from the vendors if you are going to replace it yourself.
fordfixer 09-29-2011 03:49 PM
They also now have a brass float designed just for the A.
Philip McCarty 09-29-2011 04:12 PM
It has to be well below 1/2 full before you remove the float.
700rpm 09-29-2011 05:11 PM
Disconnect your battery first!
bobgreco 09-29-2011 05:28 PM
Once you have the right tools and make sure the tank is low, it is a piece of cake to replace. The Les Andrews book has great pictures.
jojofilo88 09-29-2011 05:56 PM
its actually very easy with the ford tool. just did it last weekend on mine and it takes about 5 minutes..take off the center dash panel with the four screws and the wiring behind if you need to. make sure there not much gas in the tank and then use the tool. the whole gauge comes out and you change the float. the put it back together. very simple
Rusty Homestead Fl 09-29-2011 06:26 PM
I keep seeing reference to the "Good steel tools" for gauge removal. Is this the one that Bratton's sells? (part # 13520) I recently purchased one from them with their new guide piece, it's steel, and it has a square driver instead of being star shaped. Havn't tried it yet but the star shaped aluminum design would seem to have a better grip on the unit.
RonC 09-29-2011 07:32 PM
From Brattons you will need:
GAS GAUGE REBUILD KIT Part #13560 (has Neoprene Float - don't use a cork float anymore)
GAS GAUGE TOOL Part #13520 This is the good steel tool 2 piece set
GAS GAUGE WRENCH HOLDER Part #13525 This is handy if you have a stubborn gauge nut
As mentioned before, disconnect your battery before removing the dash.
RonC 09-29-2011 07:34 PM
I think the steel squared tool grips better.
Dave / Franklin MA 09-30-2011 06:27 AM
I've got the aluminum tools and they perform adequately. They required me to push tight to keep them from popping off while tightening, but I don't know if the steel ones grip better. My car is an early 80's resto and the parts unscrewed easily. If yours has not been taken apart for many years it could be well stuck, if so I would probably recommend going for the steel.
sethkestenbaum 09-30-2011 07:22 AM
Thanks for all the great input. I will order the parts/tools as suggested and proceed. It probably isn't a bad idea for me to "rebuild" the gauge.... it is looking a bit tired and varnished. Thanks - Seth
Dave / Franklin MA 09-30-2011 10:25 AM
If you are going to remove the gauge for any reason, it's a good time to replace and/or clean everything. The repair is dangerous enough to do the first time, so there's no sense reusing old gaskets and find out you have to do the job over again if they get damaged and leak.
Tom Wesenberg 09-30-2011 11:38 AM
Be sure to ONLY use the cork gaskets for the gas guage.
Doug in NJ 09-30-2011 12:50 PM
Has the black paint in the "0 1/4 1/2 3/4 F" markings disappeared? You can have fun restoring it:
1: Clean the curved sector with the markings real well.
2: With a tiny brush or toothpick, fill the letters with fuel-proof paint. I used a glossy black epoxy spray paint. (I sprayed some into a small cup). It will take 2 or 3 coats. Do not worry about putting on a bit too much.
3: When the paint is really dry, wet-sand the sector with something like 600 grit paper to remove all the overflow paint.
Before image: http://dougbraun.com/model_a_gallery...g2_itemId=5578
After image: http://dougbraun.com/model_a_gallery...g2_itemId=5581
Doug
Gord. B by the bay 09-30-2011 01:19 PM
I prefer to use alum. tather than the steel tool because steel can cause a "ststic" arc whereas a alum tool will not, it is a hazardous area to work in with or without gas in the tank Gord, b by the Bay
Cape Codder 09-30-2011 01:35 PM
To Fordfixer - I recently rebuilt my gas gage because of the float but could not find a supplier of the Brass Float. Can you post where you got yours from?
To Gord B. by the bay - I thought that was a good point that you had made about the steel vs the alumium. Never thought of it when I did mine. Thanks
Cape Codder
AKsportcoupe 09-30-2011 03:22 PM
removal of the gas gauge is pretty simple. I would not recommend the aluminum tool. The star and outer wrench do not fit very well. I had a heck of a time getting mine screwed down tight enough to stop any seepage.
1931 flamingo 09-30-2011 03:30 PM
Had no problem when I did mine with the alum tool. new cork gaskets, no leaks.
Cape Codder: I believe most people use a float from a tillotson carb, something that will fit thru the opening.
Paul in CT
Tom Wesenberg 10-01-2011 03:25 AM
Ditto what Don just said. I also had to modify the tools, but they work fine now.
I had one guage that was extremely hard to loosen and I had to press in with all my might and weight and use an extension on the tool to get it loose.
