End gap between cluster gear and trans case Hi, Barners
I am assembling the trans for a Late 31 c/c pickup today. Do any of you trans guys know the proper end gap between the cluster gear and the trans case? I am using new bearings and gears and a late case. I am getting about .065 thousands total gap between the gear and housing. Does this sound like too much? Should I use some of the old style brass thrust washers? If I use the washers what is the ideal gap? Thanks Guys, Don |
Re: End gap between cluster gear and trans case I have some information on my site...fwiw,jm
www.jmodela.com |
Re: End gap between cluster gear and trans case Thanks,Jim
That is the info I was looking for. I am off to make thrust washers. Thanks again, Don |
Re: End gap between cluster gear and trans case I believe Jim Schild has a copy of an original print in his book that indicates .020" max.
| All times are GMT -5. The time now is 05:07 AM. |
