1939 V/8 Engine City:
Indianapolis
State:
IN
Price:
In ad
2 Attachment(s)
1939 Ford V/8 flathead 85 HP altogether engine out of 39 coupe. All as you see in photo for $550. Located indianapolis, IN. More information, please telephone 317-846-4605. Thank you. John
Re: 1939 V/8 Engine Do you know the miles on the engine? Did it blow up or lock up, or did it just wear out? Has the engine been rebuilt before? When you took the heads off was the block standard bore or has it been worked before? Is there the large A in the center of the heads? Is the items in the picture all that goes with the deal?
Re: 1939 V/8 Engine Will you sell the intake manifold? It appears to be cast iron, is that right?
Re: 1939 V/8 Engine Btt
Re: 1939 V/8 Engine 21 studs? 39? Maybe 37?
Re: 1937 V/8 Engine Fan mount on crank identifies this as '39 DeLuxe or '40 engine. It's a 24 stud block.
Re: 1939 V/8 Engine 'A' mark in the middle of the heads?
Re: 1939 V/8 Engine what does btt mean?
Re: 1939 V/8 Engine bak to top--renews the add
| All times are GMT -5. The time now is 04:55 AM. |
