The Ford Barn
-   -   Brake drum turning question (https://www.fordbarn.com/forum/showthread.php?t=40245)
ChicagoBob 06-21-2011 09:59 AM
I have a '30 with cast iron drums. When I had one of my front hubs replaced (by mail), the swaging of the wheel studs apparently warped the drum. When the brakes are cold, there is quite a pulse as the car is slowed, but once they warm up, the pulse almost disappears. I have two questions: Would having the drum machined improve this situation? Also, are modern shops equipped to turn drums with the hubs attached?
bdentremont 06-21-2011 10:16 AM
Re: Brake drum turning question
Originally Posted by ChicagoBob (Post 226975)
... Would having the drum machined improve this situation? Also, are modern shops equipped to turn drums with the hubs attached?
I'm in the middle of installing cast iron drums too. I'm told that all new drums should be turned after attachment to the hubs, since, even if the drums are not warped, they are not necessarily exactly concentric on with the bearing races after swaging. I've also heard that the fronts are fairly standard, but that you'll have a harder time finding a shop that can handle model A rear hubs.
1931 flamingo 06-21-2011 10:19 AM
I believe on the rears if you can find a shop equipped with tooling to machine early VW's they will be able to turn the rears. Please correct me if I'm wrong.
Paul in CT
Mike V. Florida 06-21-2011 10:45 AM
Paul in CT
You're right!
Kurt in NJ 06-21-2011 11:05 AM
A warped wheel can push a drum out of round also, on my brothers car too much powdercoating in 1 area of wheel to drum contact changed the drum when the wheel was bolted up
JoeWay 06-21-2011 11:58 AM
Kurt, you have posted about this in the past. First time I read it, I checked my wheels and sanded the coating off the mating surfaces. This fixed the pulsation I was feeling. I felt that only one wheel was probably the culprit, but did them all anyway.
Thanks.
Joe
pooch 06-21-2011 05:47 PM
Luckily I had a spare rear axle in car when bought.
I was able to bolt drum to axle and mount it in a normal centre lathe.
