The Ford Barn
-   -   water pump bearing sleeve (https://www.fordbarn.com/forum/showthread.php?t=40179)
Wuudie 06-20-2011 02:05 PM
Anyone have any insght on removal of water pump bearing sleeve?
I was thinking of using a tap to screw into it and pull it out?? Thoughts? new ideas welcome/needed.
fordfixer 06-20-2011 02:55 PM
Re: water pump bearing sleeve
If you are talking about the one for the front bearing, it is quite easy to remove. It has a split in it so that aids in the removal. I usually just use a small punch and catch the grease hole in the sleeve and tap it out.
