46 truck bench seat brackets Need some help -I have a 46 1-1/2 ton truck and I purchased a new bench seat from Lebanon Bonny -but it didnt come with the mounting brackets -are there any after market mounting brackets that work -to attach to seat riser -I think they have 2 holes where they mount to the riser —Thanks
Re: 46 truck bench seat brackets Quote:
Re: 46 truck bench seat brackets I THINK the brackets are riveted to the seat fame, never seen anyone making these parts although as GB says they may not be too hard to produce, lots of parts for 42 to 47 trucks are not reproduced....
Re: 46 truck bench seat brackets I'm sorry I didn't get out there this afternoon, but I do remember that the two holes at the rear of the seat riser on each side are threaded for 1/4-28 female threads. Maybe the front of the seat riser has the bullet tips that go into one of three holes at the front of the seat. Been awhile....
Re: 46 truck bench seat brackets Thanks so much -if you could post a picture that would be great -I am trying to keep this as orginal as possible -so knowing what I am looking for would be great -
Re: 46 truck bench seat brackets 3 Attachment(s)
Took these this afternoon. Easy to make. I can't tell if there is a bullet shaped stud on the fwd end of seat riser as Mine has an added strip of 1/2" plywood all around and the bullet on my old tonner, a '38 was about 1/2" tall. I can look on a parts truck in the morning as I finally have a day off....
https://www.fordbarn.com/forum/attac...3&d=1778644415 https://www.fordbarn.com/forum/attac...4&d=1778644428 |
Re: 46 truck bench seat brackets Thank you Pete! In these photos, the seat has been slid forward to better show the hold down strap. In driving position this would put the seat about as rearward as possible. Funny when you consider I'm 5'-6". To say the seat was 'slid' forward is really not accurate, because the strap raises the seat off the base as it moves forward, and as you can see there are actually 3 holes tapped for the 1/4-28 round head screw, not 2.
Re: 46 truck bench seat brackets I looked in my parts truck that has a good seat riser and no bullet tip for locating the front end of the seat. In fact there doesn't seem to be anything up front. Maybe the seat base has parts that ride againgst the riser's lip. Where's Rawlir?
Re: 46 truck bench seat brackets 2 Attachment(s)
Here are brackets for my 2 trucks. 46 Commercial & 47 Express pickups....
I have never seen them separated from seat cushion, i suspect Period Correct USED ones would be hard to find.... |
https://www.fordbarn.com/forum/attac...7&d=1778896234 |
Re: 46 truck bench seat brackets I believe 2 screws on each side are all that anchor the seat in position. I have never seen anything that keeps the front of seat from moving. Someone told me recently that Ford gave you a choice of 2 screws in 3 holes to pick up a 1" or so in setting. Not sure of that? I do have a complete seat & back rest for sale, rebuilt, restored, ready to install, i had an extra seat & backrest, had a fellow getting ready to retire, so had him do it knowing someday someone would want it.....
| All times are GMT -5. The time now is 02:11 AM. |
