'32 Zenith choke rod? I have been asked by a friend to assist with rebuilding their '32 Zenith carb, but the thing that puzzles me is - does the '32 ("Model 'B'") have a metal choke rod similar to a Model 'A'? This car is fitted with a cable, which does not seem right. I am a Model 'A' person, so I don't really know. Any help will be appreciated
Re: '32 Zenith choke rod? |
Re: '32 Zenith choke rod? Quote:
Re: '32 Zenith choke rod? As best I can tell the choke cable set up looks correct.
On my B I just pull the choke knob out and hold it till the engine starts. Once it's running, I continue to hold the choke closed until the engine warms up enough to run without the choke. I never change the fuel mixture to keep it running when cold because it stresses the cable by turning the cable back and forth. That's why many are broken/repaired at the base. The air silencer is incorrect. It appears to have the correct Aluminum elbow but the sheet metal part is not original. There's several pictures in Dave's book. |
Re: '32 Zenith choke rod? Thanks folks. It seems as though the problem on this car is that once you set the GAV via the cable, the cable seems to work its way back to a position that interferes with the proper running of the car, like it has some kind of "memory" - what could be going wrong here?
| All times are GMT -5. The time now is 01:05 AM. |
