Clutch diameter question 3 Attachment(s)
Howdy I have a 41 Ford tudor with a 221 and a side loader transmission. Seems to be a funny year for parts/ standards. Would anyone know the size of clutch it would have. 10", 11" or 9? Trying to get parts ordered before I slide the trans and rear end out of the car to make it a quicker swap. Thanks in advance
Re: Clutch diameter question My best guess would be 9". There are a lot of not so good pressure plates out there, get your parts from Mac Vanpelt Ford parts.
Re: Clutch diameter question After 84 years, the only way to be absolutely sure is to take it apart and measure it.
Re: Clutch diameter question 1 Attachment(s)
That flywheel has the raised lip, with the pp bolts near the shoulder like my 9".
There would be an extra set of springs in the area of the red circle if it were 10 or 11" |
Re: Clutch diameter question Quote:
Re: Clutch diameter question I agree with the Deuce, at one glance you can tell the disk size by how many springs it has. Two on each of the ....What you call it...3 sections, will be a 9", three will be a 10 or 11
Re: Clutch diameter question If you could rotate the PP and look for a part number if found you would be in luck.
Re: Clutch diameter question Thanks everyone, Gonna crank it over after work and check it out. I had a 46 merc as a kid in high school and that seemed a lot more standard. 41 seems to have a lot of weird changeovers through production
Re: Clutch diameter question It's a 9". The flywheel with the raised heavy rim only accepts a 9" clutch.
Re: Clutch diameter question You're not alone, seems there are many changes across the 41 year. Never a dull moment.
| All times are GMT -5. The time now is 01:17 AM. |
