The Ford Barn
-   -   Kudos to Speedway Motors (https://www.fordbarn.com/forum/showthread.php?t=351095)
Shoebox 07-29-2025 06:08 PM
1 Attachment(s)
I know that opinions vary regarding Speedway Motors, at times my own as well. I purchased an Offenhauser 8ba block pressure testing kit back in March and used it for the first time last week. Happily the test of the passenger side was successful. Reinstalling the head plate to the other side I found that the provided sealing washers, a steel washer with rubber bonded to the bottom side, are not 100% reusable, I had about 8 bolt/washers that were bubbling under pressure. I removed those bolts and saw the washers were deformed (I had torqued bolts to the recommended 20 ft lbs) so I tapped them flat as best I could and used the one extra washer on a bolt. I had success with a couple I had massaged as well as the bolt with the new washer.
So I called Speedway, talked to some folks and explained that I was not able to completely test one block. They understood and sent me a bunch (more that I needed) of these sealing washers, will be here Saturday, at no charge.
Just thought I'd share a positive example of Customer Service.
petehoovie 07-29-2025 06:37 PM
Re: Kudos to Speedway Motors
https://www.fordbarn.com/forum/attac...0&d=1753830438
Bored&Stroked 07-29-2025 07:57 PM
Hey Shoebox, I've had the same problem with the same kit. I think I'll give them a call as well! THANKs!
Shoebox 07-29-2025 08:19 PM
Hey B&S,
By all means hit them up, just in case I got No Bueno from Speedway, (Which they were great) I found the sealing washers on Grangers. I can provide part # if needed. Thanks.
busmania 07-29-2025 10:00 PM
Shoebox, please provide. I need some. Thanks!
Shoebox 07-30-2025 12:05 PM
Actual washers in kit, HSSRSW-.38
Similar Washers-
Bolt Depot #15214
Granger #61JX71
rockfla 07-30-2025 01:47 PM
1 Attachment(s)
IF they are 3/8" bolt size, I can supply them in SS with the neoprene bonded to them........$ 9.95 per 100 plus shipping.
petehoovie 07-30-2025 02:38 PM
https://www.fordbarn.com/forum/attac...8&d=1753901222
Shoebox 07-30-2025 05:32 PM
THAT is one HECK OF A DEAL! Those look superior to what comes in the kit.
rockfla 07-31-2025 09:04 AM
that is based of my current cost on inventory....They "may" have gone up just a little bit BUT for now, what I have in stock is good at $ 9.95 per 100. I sent off to get a quote on restocking them and can let you know later today.
rockfla 07-31-2025 01:09 PM
I checked my replenishment cost on these and once my "current" supply is gone they will go up $ 1.00 to $ 10.95 per 100 plus shipping!!! I have already sold 200 and I estimate having maybe another 200 or so left before my new stock come in.
Zeke3 08-01-2025 02:52 PM
Aren’t the head bolts 7/16 thread like the studs on earlier engines?
rockfla 08-01-2025 03:07 PM
That is what I thought, 21 studs sure are!!!!! 7/16 bonded washers are NOT available to me.
