Original lifters Will straight stem valves like Chevy valves work OK with original nonadjustable lifters?
Re: Original lifters I recall that the chevy valves are longer, but I see no reason why they would not work just fine unless:
A) The groove for the keeper is too close to the end of the new length B) The stems are hardened, but only at the tip. It's always been interesting to me how after 92 years of automobile engine developement, our flathead ford valves are still the industry standard with, I would guess millions produced annually. |
Re: Original lifters Quote:
Yes. I'm running originals in my 8CM Merc engine. Chev valves need to be chosen to accommodate correct spring installed height and overall length but will otherwise do fine. |
Re: Original lifters |
| All times are GMT -5. The time now is 02:42 PM. |
