The Ford Barn
-   -   33 Ford 5w rear roll down window (https://www.fordbarn.com/forum/showthread.php?t=342165)
Rpconst 09-15-2024 04:52 PM
3 Attachment(s)
After searching this site and others relentlessly for weeks, I finally became confident enough to make a run at ordering all the parts. Here are some pics for reference. They are just mocked up for now. Please feel free to comment if something looks wrong. There was some guesswork involved. 😆 But, as a lot of things go. It doesn’t look as complicated as I made it out to be.
Thanks for all the help.
Newc 09-15-2024 08:14 PM
Re: 33 Ford 5w rear roll down window
Did all coupes in '33 have these roll down windows? My std 4cyl coupe does not have one.
Previous owners ??? Newc
DavidG 09-15-2024 08:29 PM
Theoretically, yes, as there are no parts in the August, 1934 body parts catalog for anything other than a roll-down window.
My '33 4-cyliner coupe has one.
tubman 09-15-2024 08:41 PM
I'm certainly no expert on the older Fords, but that sure looks like First Class work to me.:)
DavidG 09-16-2024 02:32 AM
Given the size of the photos, i can't tell if you have the lipped rubber channel that the glass fits into before fitting into the steel channel. Other than that, it looks to be all there, assuming that you have the steel drain pan that fits beneath the window.
Terry,OH 09-16-2024 07:30 AM
2 Attachment(s)
There is a sheet metal cover over the regulator spring. I found cup washers under the attachment screws same washers used on the toe boards. I like to stain the wood black before installation. Do you have the lower metal channels for the glass channels? there are T-nuts that the regulator screws thread into. Appears very complete.
hotrodcbx 09-16-2024 07:31 AM
I always thought that only rumble seat cars had the wind down window to facilitate talking to rumble seat passengers. Am I wrong?????
Terry,OH 09-16-2024 07:38 AM
Trunk 5-W also had the roll down window. The open window does aid in ventilation.
Rpconst 09-16-2024 09:45 AM
Thank you. You are correct. That rubber is missing. I’ve got it ordered. I have the oem drip pan that is being repaired.
Rpconst 09-16-2024 09:55 AM
Thanks good info. I like the spring cover and the black stain idea. I also see I’m missing the crank escutcheon. I have the t-nuts. I can’t find those lower retainer channels anywhere. I bought a 13 1/2” model a retainer channel from Brattons and cut it in half. Not sure if that’s gonna work. After mock up and playing with it I’m inclined to think 2 full length retainer channels might be better.
fordson 02-04-2026 01:56 PM
Hi there, i noticed that your rear window glass channel seems to have the correct length for the glass to fit in.
I ordered a glass channel from vintique which is shorter and the slider/runner is not bevelled / folded the correct way for the regulator arm to run properly.
May i ask which company your glass channel is made by and whom you ordered it from?
I opened a thread regarding my issue.
Regards Randolf
highbeams 02-04-2026 02:43 PM
the crank escutcheon, look at other years; i.e., I have a '34 crank escutcheon for my '33.
unless you're in a judging event, who cares? Thank You -
