The Ford Barn
-   -   Masking Plastic (https://www.fordbarn.com/forum/showthread.php?t=339831)
Gene F 06-28-2024 01:46 PM
Masking Plastic
When you guys paint a panel on a car, where do you get that cheap thin plastic to wrap the rest of the car and then pull it off and toss it? Seems like I saw that some place, like a hardware store, but I can not remember where.
Phil Brown 06-28-2024 01:58 PM
Re: Masking Plastic
Lowes or Home Depot has it probably find some on Amazon as well
Gene F 06-28-2024 02:00 PM
Re: Masking Plastic
This is the cheap disposable stuff, right?
Phil Brown 06-28-2024 02:07 PM
Re: Masking Plastic
1 Attachment(s)
Yea, most automotive paint shops will have something similar although more $
mcgarrett 06-28-2024 02:43 PM
Re: Masking Plastic
This will work just fine...
https://www.lowes.com/pd/Project-Sou...Mil/5003330923
Gene F 06-28-2024 03:01 PM
Re: Masking Plastic
thanks
Canton_Model_A's 06-28-2024 03:15 PM
Re: Masking Plastic
There is always this. Masking film
https://www.homedepot.com/p/3M-99-in...9-8C/203072657
jb-ob 06-28-2024 03:52 PM
Re: Masking Plastic
Be very careful using body shop masking plastic.
Excellent product to prevent over spray reaching the rest of the car. Always drape right to the wet floor to prevent over spray from drifting onto wheels & chassis.
Caution; read the label on the box as SOME plastic masking, if gotten wet, will acid stain the paint. These materials cannot be left outside in wet weather to protect the car.
Tacoma Bob 06-28-2024 04:25 PM
Re: Masking Plastic
MMM Grio's sells a disposable plastic car covers $14.00. I use them to cover my California car cover in the garage. Keeps the cigar smoke from getting on the fabric too. LOL
Gene F 06-28-2024 05:25 PM
Re: Masking Plastic
I just want to protect the balance of a car while I put a stipe on the hood.
ModelA29 06-28-2024 05:55 PM
Re: Masking Plastic
A couple of the cheapest Home Depot plastic tarps will do that job.
nkaminar 06-28-2024 08:30 PM
Re: Masking Plastic
Paint department.
Planojc 06-29-2024 08:31 AM
Re: Masking Plastic
Plastic drop cloth located in the paint section of Home Depot.
47topless 06-30-2024 09:11 AM
Re: Masking Plastic
Not to your question but....Old bed sheets work great. Easy to handle. Easy to tape the edges. Keep in place with magnets. No scratching. Don't attract dust. Reusable (wash and wear). Easy to store. Will absorb your tears if you screw-up.
jrelliott 06-30-2024 09:51 AM
Re: Masking Plastic
Got some plastic wrap for when spraying the house to mask off windows and other places you did not want painted. The unit came with tape on one edge called 3M Hand-Masker. Install on the edge you want masked off then pull the sheet down to cover the protected area. Worked great.
1crosscut 06-30-2024 05:15 PM
Re: Masking Plastic
I use painters plastic. Very light, very thin and easy to work with. Comes on a roll in a box that you can pull it out of the box to the desired length and then cut it off. Very handy for many different things.
Makes a great car cover (inside) and can be made to stay in place with a few refrigerator magnets.
