Engine pan ID 1 Attachment(s)
Howdy boys, can any of you ID this engine pan for me? Looks to be the right side. Thanks!
Re: Engine pan ID It’s NOT 1932 to 38. So you can eliminate them
Re: Engine pan ID Quote:
Re: Engine pan ID I'm thinking a driver's side pan because of the recess w/drain hole for the steering column. Don't know the year.
Pat |
Re: Engine pan ID Thanks Pat, I think right side due to the flat on the edge of the pan would mount to the right frame rail, with the right angle piece against the front crossmember. Maybe?
