Photos for David 2748-Oli pipe install 2 Attachment(s)
These are the two photos I tried to get onto this discussion. When the new gasket is installed on the end of the pipe and ready to go on the pan, there is a small round recessed area inside the pipe under the gasket. The pipe inside the oil pan protrudes slightly from the pan, but is flush when the gasket is applied.
Is there a small round gasket that fills that recessed gap when it goes onto the oil pan??? |
Re: Photos for David 2748-Oli pipe install Paul?
Re: Photos for David 2748-Oli pipe install Yes-sorry Paul2748. I tried to send the photos on his private line. Couldn't get them to download
Re: Photos for David 2748-Oli pipe install You can't attach photos to a PM. You have to PM him and let him know the photos are up.
Re: Photos for David 2748-Oli pipe install Go here on that gasket - this is the one you gave me sizes on ?? Go down about 3/4 of the page for the response by "Ted". He recommends a correctly sized o-ring.
Ted is a recognized Yblock engine builder http://forums.y-blocksforever.com/Topic165543-1.aspx |
Re: Photos for David 2748-Oli pipe install ... oh man! ... I wanted to see how the oil drain plug gasket would have worked ... :( |
Re: Photos for David 2748-Oli pipe install Gotta have the last word ???
Re: Photos for David 2748-Oli pipe install Quote:
:confused: Not really. I just wanted to see what would happen with the incorrect seal on the application. |
Re: Photos for David 2748-Oli pipe install OK, this is why I recommended beg, borrow or steal for that one gasket. It seems one has to buy a complete GASKET KIT to get it -
https://www.speedwaymotors.com/Best-...et,444528.html It seems to me either tube gaskets set (1 or 2PC) tube design would be included in their pan gasket set. Hey, they make money and I don't. Maybe FEL-PRO offers it separately? |
Re: Photos for David 2748-Oli pipe install Bob - sent you a PM.
