1939 Ford flathead belt size Hi again everyone!
Quick question: What fan belt size would be correct for my 1939 Ford flathead? The belt would cover both water pumps, the generator, and obviously the crankshaft. I tried measuring the old one and I got around 53 inches, but it’s a bit worn and not the most accurate. I saw some 52 inch ones online and was wondering would those work?? :confused: Let me know what you think is best. Thanks!! |
Re: 1939 Ford flathead belt size Most common is a B51, which is 54" long. (B series belts measure 3" longer than their part number)
Re: 1939 Ford flathead belt size Caddy , that’s why we come to the FordBarn.
Re: 1939 Ford flathead belt size 1 Attachment(s)
Re: 1939 Ford flathead belt size Quote:
Re: 1939 Ford flathead belt size Is there an echo in this room? ;)
Re: 1939 Ford flathead belt size I keep a bunch of cut belts. I set the generator or alternator down to its lowest point on the engine and then take a cut belt and wrap it around the pulleys and take a measurement of the length, maybe add just a little to it. That usually works out pretty good by the time I tighten it up. The local stores should be able to sell you a belt based on the length and if you need a little more of less you can return it and swap it out.
| All times are GMT -5. The time now is 04:19 AM. |
