Bad Inner Tubes/Ruined Tires or Tubeless A friend of mine recently drove to the Florida Keys from Idaho in one of his Model A’s. While coming home in Arkansas he experienced failure of inner tubes that he had purchased through Coker when he had also replaced tires before his trip. He had taken spare tubes with him but quickly found out he needed more tubes and tires as it ruined the tires before he could get off the road. He had new tires and tubes shipped to him while holding up in a small town. I don’t think Coker helped him with any adjustments or replacements caused from the bad tube. He had radial tires and the radial tubes.
I watched on Youtube “Team Merrill and his 29 Model A and the 2022 Great Race” this week. During that video he said that for about the past five years he stopped using tubes with his Model A tires. He said if the wheels are good and powder coated you could use the tires as tubeless. He said he has had no tire issues since changing. He said he has run 15 great races. Has anybody else changed over to running tubeless? |
Re: Bad Inner Tubes/Ruined Tires or Tubeless Quote:
I am now using Coker Radial Tubes (they seem thicker, especially around the valve stem) with the silicone talc nkaminar recommended. https://www.aircraftspruce.com/catal...clickkey=52466 No issues. There are numerous other posts on this subject. |
Re: Bad Inner Tubes/Ruined Tires or Tubeless 4 Attachment(s)
Actually here are some pictures of the "Inspection Stickers" so you know what to look for and damage they cause.
Re: Bad Inner Tubes/Ruined Tires or Tubeless I was using Coker radial tubes and had failures in one tube and determined that given what the failure looked like, that it was the label inside the tire that caused the problem. With Coker's tubes, there is a warning on the box (Hartford tubes) about removing anything inside the tire, but it's easily overlooked. I now have plenty of experience changing tires and tubes on my 1928 roadster. There has been more than one post about this and Ron Ehrenhofer mentioned it in the latest Model A News, so word is getting out about this problem. It was a pain demounting all the tires and removing those little labels, but there is no other way around it.
Coker needs to put a warning label OUTSIDE the tire that is EASILY SEEN. When I contacted Coker, they didn't seem too interested... |
Re: Bad Inner Tubes/Ruined Tires or Tubeless 2 Attachment(s)
Coker now lists the warning on the outside tire sticker.
Re: Bad Inner Tubes/Ruined Tires or Tubeless Friend of mine runs his tires tubeless. I don't. I think the wheel has to be in good condition so that the tire makes an airtight seal. In the back of my head there is a little voice saying that there is something on the market that will improve the seal that the tires makes. Maybe it's that green slime that fixes flats?
Tires can be ruined by running flat. The rim cuts the tire. It may not be noticed on the outside of the tire but the tire cords are weakened. Modern tires can withstand 200 psi but the weakened tire will hold much less and explode if the air pressure is too much. There are plenty of videos of exploding tires on the internet. These are used tires which likely have been damaged. When cages came out to put tires in when they were blown up, the purpose was misunderstood. The tire technicians complained that they did not want to get in the cage with the tire. In case anyone takes this seriously, it is intended as a joke. |
Re: Bad Inner Tubes/Ruined Tires or Tubeless 1 Attachment(s)
https://www.fordbarn.com/forum/attac...2&d=1703369713 |
When I ordered my 4 ACR's in May of this year, there were NO stickers inside the tires. Along with the warning on the outside tire sticker and the absence of stickers on the inside, It appears someone at Coker Tire got the word. |
